kvc
Community Member
Problem with NAT to two differnt ISP's
I have a router with a serial and an isdn port.
Both the ports are connected to two differnt isp's.
I have to implement NAT in both the cases. I am using ISDN as a backup to my serial link. So i want a particular set of nat to happen when serial is down and another set when when it is up.
the following is the config which i wanted.
int s0
ip address 200.1.1.2 255.255.255.248
ip nat outside
int bri0
ip address negotiated
ip nat outside
int e0
ip nat inside
ip nat inside source list 5 interface serial0 overlo
ip nat inside source list 6 interfade bri0 overload
access-list 5 permit any
access-list 6 permit any
But when i use the above statements eventhough my serial0 is down the router is still using the first nat statements only, and i am unable to access net.
Please suggest what changes should i make or is there any other alternative
Thanks in advance
Community Member
Re: Problem with NAT to two differnt ISP's
Community Member
you can try this:
ip nat inside source list 6 interface serial0 overlo
ip nat inside source list 5 interfade bri0 overload
138
