Community Member
Problem with port
I have Catalyst 2950. Before port fa0/1 was trunk but now i made it with command
switchport access vlan 1
simple access port. But when i insert cable into port-port dosn't work, don't light-nothing! How to resolve it?
2950#sh vlan
VLAN Name Status Ports
1 default active Fa0/1, Fa0/2, Fa0/4, Fa0/5, Fa0/6, Fa0/7, Fa0/8, Fa0/9, Fa0/10, Fa0/11, Fa0/12
Fa0/13, Fa0/14, Fa0/15, Fa0/16, Fa0/17, Fa0/18, Fa0/19, Fa0/20, Fa0/21, Fa0/22
Fa0/23, Fa0/24, Gi0/2
2 INTERNET active Fa0/3
1002 fddi-default active
1003 token-ring-default active
1004 fddinet-default active
1005 trnet-default active
VLAN Type SAID MTU Parent RingNo BridgeNo Stp BrdgMode Trans1 Trans2
1 enet 100001 1500 - - - - - 0 0
2 enet 100002 1500 - - - - - 0 0
3 enet 100003 1500 - - - - - 0 0
1002 fddi 101002 1500 - - - - - 0 0
1003 tr 101003 1500 - - - - srb 0 0
1004 fdnet 101004 1500 - - - ieee - 0 0
1005 trnet 101005 1500 - - - ibm - 0 0
Remote SPAN VLANs
Primary Secondary Type Ports
2950#sh run int fa0/1
interface FastEthernet0/1
no ip address
duplex full
speed 100
2950#sh ip int br
Vlan1 172.20.5.14 YES NVRAM up up
FastEthernet0/1 unassigned YES unset down down
FastEthernet0/2 unassigned YES unset up up
2950#sh int fa0/2 switchport
Switchport: Enabled
Administrative Mode: dynamic desirable
Operational Mode: static access
Administrative Trunking Encapsulation: dot1q
Operational Trunking Encapsulation: native
Negotiation of Trunking: On
Access Mode VLAN: 1 (default)
Trunking Native Mode VLAN: 1 (default)
Administrative private-vlan host-association: none
Administrative private-vlan mapping: none
Operational private-vlan: none
Trunking VLANs Enabled: ALL
Pruning VLANs Enabled: 2-1001
Protected: false
Voice VLAN: none (Inactive)
Appliance trust: none
2950#sh int fa0/1 switchport
Switchport: Enabled
Operational Mode: down
Protected: false
Re: Problem with port
If you try
sh int fa 0/1
is the output
FastEthernet0/21 is down, line protocol is down (notconnect)?
If yes, the problem is in cable or PC NIC.
If you connect the PC to another port, does it work OK?
If you are sure cable and NIC is OK, try to check the speed and duplex.
Last chance is to try
switchport mode access
to force the port to become access one.
(But it should't be necessary, it should work OK with the current setting.)
Milan
Community Member
sound like ure having problems with auto-negotiation, i assume ure PC's NIC is set to auto, while i see ure switch is set to 100Mbps and FD. Some NIC's dont auto-negotiate properly. wud suggest you set the switch port to auto auto , or set the PC's NIC to 100Mbps and FD. Then see whether u get a Link.
Rgds,
NY.
Community Member
2950#sh int fa0/1
FastEthernet0/1 is down, line protocol is down
Hardware is Fast Ethernet, address is 000b.5f84.3141 (bia 000b.5f84.3141)
MTU 1500 bytes, BW 100000 Kbit, DLY 1000 usec,
reliability 251/255, txload 1/255, rxload 1/255
Keepalive set (10 sec)
Full-duplex, 100Mb/s
input flow-control is off, output flow-control is off
Last input 5w1d, output 5w1d, output hang never
Queueing strategy: fifo
Output queue :0/40 (size/max)
751516725 packets input, 399717964 bytes, 0 no buffer
Received 3686335 broadcasts, 0 runts, 0 giants, 0 throttles
67607 input errors, 67500 CRC, 3 frame, 0 overrun, 1366 ignored
0 watchdog, 570557 multicast, 9138 pause input
983658330 packets output, 911392852 bytes, 0 underruns
239814 output errors, 21401 collisions, 6 interface resets
0 babbles, 239814 late collision, 65163 deferred
When i insert cable into other port-it's work,when i return back ( in fa0/1) - don't work! :-(
Community Member
i run again commands:
it's from worked port(fa0/2 )-
HobbitHole#sh int fa0/2 sw
Switchport: Enabled
Protected: false
it's from not-worked port(fa0/1)-
HobbitHole#sh int fa0/1 sw
Switchport: Enabled
Administrative Mode: static access
Negotiation of Trunking: Off
Protected: false
I found difference in Negotiation of Trunking:? May be here?Don't know what to think!
111
