Community Member
problem with "non-trunking" switch configuration
These are the logs we are getting on a C6509 connected with a 3524:
2003 Mar 27 17:04:26 EET +02:00 %CDP-4-NVLANMISMATCH:Native vlan mismatch detected on port 3/25
2003 Mar 27 17:34:26 EET +02:00 %CDP-4-NVLANMISMATCH:Native vlan mismatch detected on port 3/25
2003 Mar 27 18:04:27 EET +02:00 %CDP-4-NVLANMISMATCH:Native vlan mismatch detected on port 3/25
2003 Mar 27 18:34:27 EET +02:00 %CDP-4-NVLANMISMATCH:Native vlan mismatch detected on port 3/25
2003 Mar 27 19:04:28 EET +02:00 %CDP-4-NVLANMISMATCH:Native vlan mismatch detected on port 3/25
But we don't have any trunking configured on both sides!!!
sw-core-ath-02> (enable) sh cdp nei
* - indicates vlan mismatch.
# - indicates duplex mismatch.
Port Device-ID Port-ID Platform
3/25 sw-dial-ath-01 FastEthernet0/23* cisco WS-C3524-XL
sw-core-ath-02> (enable) sh port 3/25
Port Name Status Vlan Duplex Speed Type
3/25 sw-dial-ath-01 connected 90 full 100 10/100BaseTX
Port AuxiliaryVlan AuxVlan-Status InlinePowered PowerAllocated
Admin Oper Detected mWatt mA @42V
3/25 none none - - - - -
Port Security Violation Shutdown-Time Age-Time Max-Addr Trap IfIndex
3/25 disabled shutdown 0 0 1 enabled 34
Port Num-Addr Secure-Src-Addr Age-Left Last-Src-Addr Shutdown/Time-Left
3/25 0 - - - - -
Port Broadcast-Limit Multicast Unicast Total-Drop Action
3/25 - - - 0 drop-packets
Port Send FlowControl Receive FlowControl RxPause TxPause
admin oper admin oper
3/25 off off off off 0 0
Port Status Channel Admin Ch
Mode Group Id
3/25 connected off 23 0
Port Status ErrDisable Reason Port ErrDisableTimeout Action on Timeout
3/25 connected - Enable No Change
Port Align-Err FCS-Err Xmit-Err Rcv-Err UnderSize
3/25 0 0 0 0 0
Port Single-Col Multi-Coll Late-Coll Excess-Col Carri-Sen Runts Giants
3/25 0 0 0 0 0 0 0
Port Last-Time-Cleared
3/25 Thu Jan 9 2003, 07:52:03
Idle Detection
sw-core-ath-02> (enable) sh trunk 3/25
* - indicates vtp domain mismatch
Port Mode Encapsulation Status Native vlan
3/25 off negotiate not-trunking 90
Port Vlans allowed on trunk
3/25 1-1005,1025-4094
Port Vlans allowed and active in management domain
3/25 90
Port Vlans in spanning tree forwarding state and not pruned
3/25
sw-core-ath-02> (enable) sh ver
WS-C6509 Software, Version NmpSW: 7.3(1)
Copyright (c) 1995-2002 by Cisco Systems
NMP S/W compiled on Jul 8 2002, 16:10:20
System Bootstrap Version: 7.1(1)
Hardware Version: 3.0 Model: WS-C6509 Serial #: TBP06440078
PS1 Module: WS-CAC-1300W Serial #: SNI06420341
PS2 Module: WS-CAC-1300W Serial #: SNI06420333
Mod Port Model Serial # Versions
1 2 WS-X6K-SUP2-2GE SAL06396RZV Hw : 3.10
Fw : 7.1(1)
Fw1: 6.1(3)
Sw : 7.3(1)
Sw1: 7.3(1)
WS-F6K-PFC2 SAL06396RE1 Hw : 3.3
2 8 WS-X6408A-GBIC SAL06303ANC Hw : 2.1
Fw : 5.4(2)
Sw : 7.3(1)
3 48 WS-X6348-RJ-45 SAL06386J8E Hw : 6.2
Fw : 5.4(2)
Sw : 7.3(1)
DRAM FLASH NVRAM
Module Total Used Free Total Used Free Total Used Free
1 131072K 58703K 72369K 32768K 7617K 25151K 512K 286K 226K
Uptime is 120 days, 4 hours, 32 minutes
sw-dial-ath-01#sh interfaces fa0/11 switchport
Switchport: Enabled
Administrative mode: static access
Operational Mode: static access
Administrative Trunking Encapsulation: isl
Operational Trunking Encapsulation: isl
Negotiation of Trunking: Disabled
Access Mode VLAN: 9 (VLAN0009)
Trunking Native Mode VLAN: 1 (default)
Trunking VLANs Enabled: NONE
Pruning VLANs Enabled: NONE
Priority for untagged frames: 0
Override vlan tag priority: FALSE
Voice VLAN: none
Appliance trust: none
Self Loopback: No
sw-dial-ath-01#sh ver
IOS (tm) C3500XL Software (C3500XL-C3H2S-M), Version 12.0(5)WC7, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2003 by cisco Systems, Inc.
Compiled Wed 05-Mar-03 09:59 by antonino
Image text-base: 0x00003000, data-base: 0x0034DEE8
ROM: Bootstrap program is C3500XL boot loader
sw-dial-ath-01 uptime is 1 day, 12 hours, 54 minutes
System returned to ROM by reload
System restarted at 06:32:38 EET Wed Mar 26 2003
System image file is "flash:c3500xl-c3h2s-mz.120-5.WC7.bin"
cisco WS-C3524-XL (PowerPC403) processor (revision 0x01) with 8192K/1024K bytes of memory.
Processor board ID FAA0437Y0AM, with hardware revision 0x00
Last reset from warm-reset
Processor is running Enterprise Edition Software
Cluster command switch capable
Cluster member switch capable
24 FastEthernet/IEEE 802.3 interface(s)
2 Gigabit Ethernet/IEEE 802.3 interface(s)
32K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address: 00:03:6B:D9:64:C0
Motherboard assembly number: 73-3904-11
Power supply part number: 34-0851-02
Motherboard serial number: FAA0436A4L5
Power supply serial number: PHI0406029Y
Model revision number: A0
Motherboard revision number: A0
Model number: WS-C3524-XL-EN
System serial number: FAA0437Y0AM
Configuration register is 0xF
Bronze
Re: problem with "non-trunking" switch configuration
I think it is a VLAN mismatch and NOT a Native VLAN mismatch. Port 3/25 of sw-core-ath-02 was configured for VLAN 90 while Fa0/11 of sw-dial-ath-01 was configured for VLAN 9. If this is the case, I guess it was because of a typo error.
[Cat6500]
[Cat3524]
Switchport: Enabled
********************Access Mode VLAN: 9 (VLAN0009)
Voice VLAN: none
Self Loopback: No
Community Member
I know these are different vlans.
But that souldn't be a problem because the switches aren't trunked.
it seems like you have a port in VLAN90 on one side and in VLAN9 on the other side.
Milan
Community Member
Since both switches belong to different VTP domains, that shouldn't be a problem.
What's the problem then?
If you want to stop receiving error messages
set logging level cdp 3 default
in your C6509 config and everybody's happy.
Milan
Community Member
This way i simply ignore the error. But what i'm trying to do is to solve it.
Or is it a bug?
Community Member
Error Message Decoder
1. %CDP-4-NVLANMISMATCH: Native vlan mismatch detected on port [dec]/[dec]
This message indicates that the native VLAN is different from the one set on at least one of the neighboring ports. [dec]/[dec] is the module number/port number of the mismatched port.
Recommended Action: Check the native VLAN settings. If the VLAN configuration does not match, set it appropriately. If no apparent mismatch is found, contact your technical support representative.
It is not a bug.
The switch is getting an info from the other side via CDP that the other switch has the line assigned to another VLAN.
This is a "suspicious" situation. So a warning (level 4 severity) is sent to syslog.
If you want to design your network this way - you can and there is nothing to fix.
But you will be still getting this messages to the syslog unless you ignore them via config setting I described before.
Milan
Community Member
Another 3524 with 120-5.3.WC.1 and the same config, doesn't cause such a problem.
Maybe something has changed in ios?
Is it connected to the same C6509?
And do you see a native VLAN mismatch using sh cdp nei?
Milan
Community Member
I'm dealing with similar problem . I thought it might be helpful to you guyes.
The network is as follows
gig0/2 8/10 4/15 gig0/2
3500xl-1-------------------------6509-------------------3500xl-2
vlan1 vlan102 vlan125 vlan1
Same cat6509 is connected to two 3500xl switches. Ports on 6509 are in vlan 102 and vlan 125 and ports on both cat3500 are in vlan1. i'm getting following error for port 4/15
GMT+00:00","CDP","4","NVLANMISMATCH","Native vlan mismatch detected on port 4/15","*"
Both 3500xls are having similar config and only difference is in the software. The switch running 12.0(5)WC3b is having problem and switch running 12.0(5.3)wc(1) is not reporting anything.
In my opinion its down to software. Will let you know about the result once we manage to upgrade 3500xl-2 to 12.0(5.3)wc(1)
Atul
I can't beleive this should be an IOS version problem. Actually it's the 6509 reporting the message.
Are you sure both 3500XLs are running CDP ver 2?
What do you see when issuing sh cdp nei det on 6509?
Do you see the native VLAN info for both 3500s?
MIlan
Community Member
hi
Please check the 'sh cdp nei det ' from cat6509 . I get native vlan info on 4/15 but nothing for 8/10. let me have ypur thoughts.
Atul
Port (Our Port): 8/10
Device-ID: AO-NC41-AS-102-4
Device Addresses:
IP Address: 10.16.102.14
Holdtime: 125 sec
Capabilities: TRANSPARENT_BRIDGE SWITCH
Version:
IOS (tm) C3500XL Software (C3500XL-C3H2S-M), Version 12.0(5.3)WC(1), MAINTENAN
CE INTERIM SOFTWARE
Copyright (c) 1986-2001 by cisco Systems, Inc.
Compiled Mon 30-Apr-01 07:51 by devgoyal
Platform: cisco WS-C3524-XL
Port-ID (Port on Neighbors's Device): GigabitEthernet0/2
VTP Management Domain: unknown
Native VLAN: unknown
Duplex: full
Port (Our Port): 4/15
Device-ID: AO-NC51-AS-125-3
Device Addresses:
IP Address: 10.16.125.13
Holdtime: 166 sec
Version:
IOS (tm) C3500XL Software (C3500XL-C3H2S-M), Version 12.0(5)WC3b, RELEASE SOFT
WARE (fc1)
Copyright (c) 1986-2002 by cisco Systems, Inc.
Compiled Fri 15-Feb-02 10:51 by antonino
Native VLAN: 1
Duplex: full
Seems like the switch connected to 8/10 is not sending CDP ver 2.
Go to it's console and try
sh cdp
The output should like:
Global CDP information:
Sending CDP packets every 60 seconds
Sending a holdtime value of 180 seconds
Sending CDPv2 advertisements is enabled
If CDPv2 is not enabled you don't get the native VLAN info.
Milan
Community Member
All three switches send CDP V2 . Please see below
Atul
AO-WCR1-DS-1> sh cdp
CDP : enabled
Message Interval : 60
Hold Time : 180
Version : V2
AO-WCR1-DS-1>
AO-NC51-AS-125-3#sh cdp
AO-NC51-AS-125-3#
AO-NC41-AS-102-4>sh cdp
AO-NC41-AS-102-4>
I think I've found the bug descriptions on CCO.
See bugs CSCdt90642 (Cat3500 not sending native VLAN info in CDP v2)and CSCdw38221 (explaining that CDP-4-NATIVE_VLAN_MISMATCH error is an expected behaviour).
Milan
Community Member
Hi Milan,
I can confirm that downgrading the software to 12.0(5.3)wc(1) has resolved the issue. Many thanks for your input on this.
Atul
Hi Atul,
but 12.0(5.3)wc(1) is the version containing the bug - CDP v2 not sending native VLAN info.
So downgrade is some kind of workaround - error messages are not sent anymore - but if you upgrade in the future you'll get the messages again.
Milan
206
