problem with Software Management CW200
rrobia
Hello David
How are you doing?
I try to use Software Management to add images but when I try to import
images from temporary location to
software image library.
I got this massage Attributes cannot be retrieved from image file, check the
file permissions and the file is a valid image
and this happen just with 7513 router
best regards
rmushtaq
Level 8
Level 8
What version of RME is this?. Are you getting this error message when you add images to the library using File System as the image source?
our RME Ver 3.3
i got it when i added images to the library using divice or network
thanks
Can you add the IOS image for this same device from CCO instead of device/network?.
I just have this problem with 7513 also I cannot use cco
so may be the problem from our routers like something not enable
