Problem with STP on redundant Catalyst 3550
Hi all,
i have the szenario below:
Cat1(EMI) Cat2(EMI)
I 3550 I------I 3550 I
FE0/5 FE0/5
I I
I I
I 3COM I
Config Cat1 Config Cat2
spanning-tree vlan 3 priority 20480 spanning-tree vlan 3 priority 28672
interface FastEthernet0/5
switchport access vlan 3
switchport trunk encapsulation dot1q ................................................ how on Cat1
no ip address
no cdp enable
If i power on the cat2 Switch, FE0/5 on Cat1 go in BLK-Mode and i receive
the message:
5w6d: %SPANTREE-7-RECV_1Q_NON_TRUNK: Received 802.1Q BPDU on non trunk FastEthernet0/8 VLAN3.
5w6d: %SPANTREE-7-BLOCK_PORT_TYPE: Blocking FastEthernet0/5 on VLAN0003. Inconsistent port type.
Can anybody tell me what is my problem?
Has anybody an example configuration for Catalyst 3550 with 3Com?
Thanks in advance
Lorenz
Bronze
Re: Problem with STP on redundant Catalyst 3550
Probably caused by misconfiguration. You might want to try the following:
[Cat1]
switchport mode trunk
switchport allowed vlan add 3
switchport trunk native vlan 3
HTH.
Hi A.Manosca,
first once thank you for the fast answer.
When i use the parameter "switchport allowed vlan add 3 ", than this
interface get information for the vlan 3 only?
What have to i configure on the 3Com?
Is the parameter "switchport trunk native vlan 3 " necessary?
Lorenz
Bronze
Yes, the "switchport trunk allowed vlan add 3" command should be used if you
only want to allow vlan 3 to pass through the trunk. But you have to
explicitly disable other vlans. For example:
switchport allowed vlan remove 2,4-4094
and if you want to add other vlans, just use the 'add' option.
The command "switchport trunk native vlan 3" is used if you want to set
the native vlan of the trunk port to VLAN 3. All untagged traffic will
use VLAN 3. The default is VLAN 1.
As for you question about 3COM, sorry but I'm not familiar with 3COM
switches. But I'm sure there are documentations that could help.
Specifying your objective for this setup will help.
79
