problem with supervisor VS-S720-10G boot
Hi I have a problem, I have a switch 6509 with two supervisors, one of them was with alarm, so I entered to the device by console, and it was in mode rommon, so what I did was to make that load the image, after I rebooted the device, all the led turn to green and I could see by the console the it was downloading the image, but then automatically it reboot by itself many time, so I had to take out that supervisor.
Here is what the console show me.
System Bootstrap, Version 12.2(17r)SX7, RELEASE SOFTWARE (fc1)
Copyright (c) 2009 by cisco Systems, Inc.
Cat6k-Sup720/RP platform with 1048576 Kbytes of main memory
Download Start
Download Completed! Booting the image.
Self decompressing the image : ############################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################# [OK]
running startup....
              Restricted Rights Legend
Use, duplication, or disclosure by the Government is
subject to restrictions as set forth in subparagraph
(c) of the Commercial Computer Software - Restricted
Rights clause at FAR sec. 52.227-19 and subparagraph
(c) (1) (ii) of the Rights in Technical Data and Computer
Software clause at DFARS sec. 252.227-7013.
           cisco Systems, Inc.
           170 West Tasman Drive
           San Jose, California 95134-1706
Cisco IOS Software, s72033_rp Software (s72033_rp-IPSERVICESK9_WAN-VM), Version 12.2(33)SXI3, RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2009 by Cisco Systems, Inc.
Compiled Tue 27-Oct-09 05:12 by prod_rel_team
Image text-base: 0x01020150, data-base: 0x01021000
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
cisco WS-C6509-E (R7000) processor (revision 1.5) with 1040384K/8192K bytes of memory.
Processor board ID SMG1414N00E
SR71000 CPU at 600Mhz, Implementation 1284, Rev 1.2, 512KB L2 Cache
Last reset from s/w reset
1 Virtual Ethernet interface
198 Gigabit Ethernet interfaces
4 Ten Gigabit Ethernet interfaces
1917K bytes of non-volatile configuration memory.
65536K bytes of Flash internal SIMM (Sector size 512K).
Error: router peer template mode is NULL
Error: router session template mode is NULL
System Bootstrap, Version 8.5(4)
Copyright (c) 1994-2009 by cisco Systems, Inc.
any advice
best regard
Paolo Kobashikawa
Everyone's tags (3)
223
