Problem with Switch at BOOT
Hi I have this problem when I boot the switch could you please tell me if it could be faulty hardware
C3500XL Boot Loader (C3500-HBOOT-M) Version 12.0(5.3)WC(1), MAINTENANCE INTERIM SOFTWARE
Compiled Mon 30-Apr-01 07:51 by devgoyal
starting...
Base ethernet MAC Address: 00:08:a3:58:bc:00
Xmodem file system is available.
Initializing Flash...
flashfs[0]: 163 files, 2 directories
flashfs[0]: 0 orphaned files, 0 orphaned directories
flashfs[0]: Total bytes: 3612672
flashfs[0]: Bytes used: 3095040
flashfs[0]: Bytes available: 517632
flashfs[0]: flashfs fsck took 4 seconds.
...done Initializing Flash.
Boot Sector Filesystem (bs:) installed, fsid: 3
Parameter Block Filesystem (pb:) installed, fsid: 4
Loading "flash:c3500xl-c3h2s-mz.120-5.WC8.bin"...######################################################################################################################################################################################
File "flash:c3500xl-c3h2s-mz.120-5.WC8.bin" uncompressed and installed, entry point: 0x3000
executing...
Restricted Rights Legend
Use, duplication, or disclosure by the Government is
subject to restrictions as set forth in subparagraph
(c) of the Commercial Computer Software - Restricted
Rights clause at FAR sec. 52.227-19 and subparagraph
(c) (1) (ii) of the Rights in Technical Data and Computer
Software clause at DFARS sec. 252.227-7013.
cisco Systems, Inc.
170 West Tasman Drive
San Jose, California 95134-1706
IOS (tm) C3500XL Software (C3500XL-C3H2S-M), Version 12.0(5)WC8, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2003 by cisco Systems, Inc.
Compiled Thu 19-Jun-03 12:37 by antonino
Image text-base: 0x00003000, data-base: 0x0034E2F4
Initializing C3500XL flash...
flashfs[1]: 163 files, 2 directories
flashfs[1]: 0 orphaned files, 0 orphaned directories
flashfs[1]: Total bytes: 3612672
flashfs[1]: Bytes used: 3095040
flashfs[1]: Bytes available: 517632
flashfs[1]: flashfs fsck took 4 seconds.
flashfs[1]: Initialization complete.
...done Initializing C3500XL flash.
C3500XL POST: System Board Test: Passed
C3500XL POST: Daughter Card Test: Passed
C3500XL POST: CPU Buffer Test: Passed
C3500XL POST FAILURE: CPU Notify RAM Test: Failed
C3500XL POST FAILURE: Error with CPU Interface CPU Notify RAM POST.
C3500XL POST FAILURE: CPU Interface Test: Failed
C3500XL POST FAILURE: Cannot test CPU Interface ASIC due to failure of
C3500XL POST FAILURE: CPU Interface CPU Notify RAM
C3500XL POST FAILURE: Testing Switch Core: Failed
C3500XL POST FAILURE: Testing Buffer Table: Failed
C3500XL POST FAILURE: Data Buffer Test: Failed
C3500XL POST FAILURE: Configuring Switch Parameters: Failed
C3500XL POST FAILURE: Switch Core failing because of CPU Interface Failure
C3500XL POST FAILURE: AT: Failing because of CPU-Interface failure
C3500XL POST FAILURE: Cannot test Modules due to failure of Switch Core POST
Rick
1 REPLY
Bronze
Re: Problem with Switch at BOOT
hardware error. call cisco and describe the POST FAILURES.
200
