Community Member
Problem with T-1 interface
Recently, I purchased a T-1 connection and a 2610 router with an internal WIC CSU/DSU. The connection was installed and tested. But have yet to get on-line. For soem reason all I can do is ping our suppliers gateway.
I can ping there gateway and my interface IP , but packets will not route further. Their NOC claims this is our configuration problem, however I have followed there , as well as, Cisco configuration instructions perfectly. I am new at routing and believed I have overlooked or am ignorant am some minor setting.
Global values:
Internet Protocol routing is enabled
Ethernet0/0 is up, line protocol is up
Internet address is 216.248.xx.xx/27
Serial0/0 is up, line protocol is up
Internet address is 216.248.xx.xx/30
Interface serial 0/0
service-module t1 clock source internal
service-module t1 timeslots 17-24 speed 64
service-module t1 framing esf
service-module t1 linecode b8zs
ip address 216.248.x.x 255.255.255.x
encapsulation ppp
fair-que
no shut
Any ideas?
Community Member
Re: Problem with T-1 interface
Sounds like you have a routing issue. I am assuming that this is being used to connect to the interenet. With this in mind, make sure that you have a default gateway set on the router(ip route 0.0.0.0 0.0.0.0 x.x.x.x). If this is done then more than likely the telco has some routing issues also. Try using the traceroute command to determine where the packets are being lost.
Hope this helps.
Community Member
I looked up the command at Cisco for setting a static route, but I am not excatly sure what to do could someone give me an example. I also noticed you had 0.0.0.0 as the route is that what I need?
I do have to use routing protocols as they advertise on there end.
Also how do I set the gateway of last resort?
Community Member
I am sorry I meant I do not have to use routing protocols.
Community Member
You have a pretty simple configuation. All you need is a Default Route. In your case you need to add in global config mode:
router(config)#ip route 0.0.0.0 0.0.0.0 216.248.x.x (your ISP's router address)
Let us know if that fixes the problem!
Thanks.
Community Member
Yes that took care of the problem. Thanks for everyone's help. Now, it is on to ACL's and security.
198
