Problem with the distribute image ... Please help
My problem is the following one :
I want upgrade several of my switches (Catalyst 3550)from an IOS to another, so I use
CW2000-->RME-->Software Management-->Distribute images
- Device type : cisco IOS
- I select my switches
- here what I have on the screen
192.168.128.31
C3550, 63 MB RAM
flash:c3550-i9q3l2-mz.121-11.EA1/c3550-i9q3l2-mz.121-11.EA1.bin, 12.1(11)EA1, LAYER_2|MIN_DRAM_MEG=32
Image: 12.1(12c)EA1-LAYER_3|MIN_DRAM_MEG (5.33 MB )
Flash: flash (11.08 MB/15.26 MB)
192.168.128.33
C3550, 63 MB RAM
- Next
Verify Image Upgrade : Status=Passed
- Next
- Next
Time to download : immeditely
reboot : immediately after download
Next ....
And the problem is :
Just the first switch is upgraded, it seems perfect but I receive a mail :
Loading image file to flash device : c3550-i5q3l2-tar.121-12c.EA1.tar --> flash:c3550-i5q3l2-tar.121-12c.EA1.tar
Loading image file to flash device is complete
Retrieving config file during software upgrade process ...
Current device config has been backed up to C:/PROGRA~1/CSCOpx/files/schedule/2/192.168.128.23_cfg
Reloading device ...
Reboot complete, Verifying Software Upgrade now ...
Reboot done successfully and the device is back to normal operation ...
Error: Job has halted execution.
Reason: Job may have been halted because of machine reboot.
I don't understand, please help.
We have 17 new switches and I don't want upgrade them one by one....
Thanks in advance
Best regards,
Guillaume
  • Other Network Infrastructure Subjects
1 REPLY
Re: Problem with the distribute image ... Please help
I've noticed similar problem upgrading Cat3500XL switches:
"Reloading device ...
Reboot failed on device.
Error Info Code: '4259'
Message: 'Device Error: Device reboot operation failed.'
Job encountered error. Job aborted."
But after issuing another image distribution job with "Do not reboot" option everything was OK.
So there might be a bug regarding "Reboot" job option.
I would try to distribute images to 2 devices without reboot option and see if it works OK.
Milan
118
