Problem with The Router's memory
hi i have a 3800 router that's used as my internet router in the company  recently i found the router crashes and i have to do hard restart to the router in oreder to be up and running and when logged to the consle of my router i found this error messeage  and i can;t even loggin with my consloe either untill i restart the router
*Apr 25 06:20:28.603: %BCM_GEWAN-3-SNMP_REG_FAIL: GigabitEthernet0/0 SNMP high capacity counter register failed
*Apr 25 06:20:29.283: %SYS-2-CHUNKEXPANDFAIL: Could not expand chunk pool for ipnat node. No memory available
-Process= "Chunk Manager", ipl= 3, pid= 1
-Traceback= 6116F0F8 6002EA1C
%% Low on memory; try again later
*Apr 25 06:20:38.599: %BCM_GEWAN-3-SNMP_REG_FAIL: GigabitEthernet0/0 SNMP high capacity counter register failed
*Apr 25 06:20:39.515: %SYS-2-CHUNKEXPANDFAIL: Could not expand chunk pool for ipnat node. No memory available
*Apr 25 06:20:48.599: %SYS-2-MALLOCFAIL: Memory allocation of 65536 bytes failed from 0x6003078C, alignment 0
Pool: Processor  Free: 46892  Cause: Not enough free memory
Alternate Pool: None  Free: 0  Cause: No Alternate pool
-Process= "Net Background", ipl= 0, pid= 32
-Traceback= 6116F0F8 600180A8 6001CDF0 60030794 60017DA0 6001AC8C 614B4AF4 614B4D68 609F0BB0 609E43AC 6049ADC4 6049B0B0
*Apr 25 06:20:48.603: %BCM_GEWAN-3-SNMP_REG_FAIL: GigabitEthernet0/0 SNMP high capacity counter register failed
*Apr 25 06:20:49.751: %SYS-2-CHUNKEXPANDFAIL: Could not expand chunk pool for ipnat node. No memory available
*Apr 25 06:23:54.947: %ALIGN-3-SPURIOUS: Spurious memory access made at 0x61732D
60 reading 0x36
*Apr 25 06:23:54.947: %ALIGN-3-TRACE: -Traceback= 61732D60 61736970 61738690 617
3ADE4 615835E0 61581F20 61582140 615821FC
*Apr 25 06:20:58.599: %BCM_GEWAN-3-SNMP_REG_FAIL: GigabitEthernet0/0 SNMP high capacity counter register failed
*Apr 25 06:20:59.983: %SYS-2-CHUNKEXPANDFAIL: Could not expand chunk pool for ipnat node. No memory available
1 REPLY
Hall of Fame Super Gold
Re: Problem with The Router's memory
Likely IOS bug, update it.
1301
