Community Member
Problem with Trunk ISL and Native VLAN
Hi, I need help. Executing show tech-support i see the next messages:
WARNING: The neighbors with the following device IDs have an unknown devices.
Why i see this warning?
I have configured trunk links isl and every switch have a VLAN administrative diferent the VLAN 1.
Bronze
Re: Problem with Trunk ISL and Native VLAN
I've never heard/seen that one before. Did you ever find out what was causing it?
Gold
what are the neighboring devices ? and what are the device IDs ?
I suspect a cdp problem rather than an ISL issue, unless the neighbors on the
trunks are non cisco, in which case you should consider 802.1q
117
