problem with vpn device
Hi all i have a vpn device that sits behind a natted address in my network, it comes in via one firewall that permits the ports and natted on here, but to get back out using the default route, it takes a different path via another pix, it will not let us ping anything from the internet even though on the other pix icmp is let through inbound, do I need to use a route map so it goes via the pix it came in ?
Re: problem with vpn device
You can use a route map, but I would suggest using a static route to identify the interseting traffic that needs to be routed to the originating PIX. ex. route inside 192.168.1.x 255.255.255.0 inside interface of PIX.
the route is already set up on the pix, it still didnt work, I have set the route map up on the remote router and now it seems to be working ok must of been the other pix
105
