Problem with web access under http://localhost:1741/ [CW2000]
I have RME 3.3 on HPUX, Campus Manager, CD-ONE etc... Everything worked very good until few days ago I tried to login into my web page http://host:1741/ and I couldn't see: RME, Campus manager menus and under "VPN Management Solution" there are no any options available. I vahe access to "Server Configuraion" and "CiscoView" and a little more ...
Next I tried to login as a default admin user and I saw the same situation. now all users have the same situation - we can't see menu as I mentioned...
Any suggestion ??? Please help
Pawel
Re: Problem with web access under http://localhost:1741/ [CW2000
Due to some limitations in CORBA, there will be problems if you connect to CW2000 as "http://localhost:1741". Use the hostname or IP address of the server in URL. Eg., use "http://:1741" or "http://:1741".
-Ganesh.
Still the same problem ...
BTW - I've cheked all processess - everything works ...
Pawel
Check the processes set in CW2K. Maybe someone have deleted some system files for this server where you'd installed CiscoWorks. Do you encountered any errors when you start the program?
Kevin
Blue
What web browser version are you using?. Also, does it happen only from the server or from the client as well?
On checking with Pawel, I came to know that the XML files responsible for showing up RME and Campus Mgr menu items are missing from the server.
Pawel,
To start with, did you install an evaluation copy of RME 3.3 or Campus Manager? If the evaluation period has expired, the corresponding products will be inaccessable, and hence the missing menu items.
OR,
Did you install RME 3.3 afresh or went thro' an upgrade procedure from an older version of RME?
-Ganesh.
I don't have XML files ... so I'm ready to reinstall all my Cisco management...
I have full verion of : Campus Manager (3.1), Traffic Director (5.8.2), CD-One (4th Edition) and RME (3.3)... On PC I have IE 6.0 (polish edition :-) ) On HPUX server I have Netscape browser but I can't use it because it has "cookie disabled" even I check option to accept cookies...
I've checked all log files - it seems that there are no errors and I can see that all processes/logs/poolers/collections which I have run before crash are still running...
Pawel
PS Sorry 4 my english ... :-(
DId you check all log-files in directory: /var/adm/CSCOpx/log ?
Greetings ,
Maurice
Yeap ... but reinstalling was a very good move :-)))) [but on HPUX it took me 2 days :( ]
thx
Pawel
266
