problem2 dialing bri_to_pri
I have still problems when dialing from the cisco 2651 to the CiscoRAS. I ping from the cisco2651 to the IP adress 192.168.10.3
In earlier conversations I made some changes, but it wasn't enough
Here below you see the config files and debug information of the 2651 router.
Cisco2651#sh runn
Building configuration...
Current configuration : 1626 bytes
version 12.2
service timestamps debug uptime
service timestamps log uptime
service password-encryption
hostname Cisco2651
enable password 7 045802150C2E
ip subnet-zero
ip cef
no ip domain-lookup
ipx routing 1897.7854.6c4e
isdn switch-type basic-net3
interface FastEthernet0/0
description connected to EthernetLAN
ip address 172.16.1.2 255.255.0.0
duplex auto
speed auto
ipx network 10 encapsulation SAP
interface BRI0/0
ip address 192.168.10.2 255.255.255.0
encapsulation ppp
dialer idle-timeout 30
dialer map ip 192.168.10.3 name CiscoRAS broadcast xxxxxxx
dialer watch-group 2
dialer-group 3
ppp authentication pap callin
ppp pap sent-username ISDNBACKUP password 7 Wireless
interface FastEthernet0/1
description connected to EthernetLAN_1
ip address 172.17.1.2 255.255.0.0
duplex auto
speed auto
ipx network 11 encapsulation SAP
router eigrp 100
network 11.0.0.0
network 172.16.0.0
network 172.17.0.0
network 192.168.10.0
no auto-summary
no eigrp log-neighbor-changes
ip classless
ip forward-protocol udp 6502
ip route 0.0.0.0 0.0.0.0 172.16.1.1
ip route 172.17.0.0 255.255.0.0 FastEthernet0/1
ip route 192.168.88.0 255.255.255.0 FastEthernet0/1
ip http server
ip pim bidir-enable
access-list 103 deny eigrp any any
access-list 103 permit ip any any
dialer watch-list 2 ip 11.1.1.1 255.0.0.0
dialer-list 3 protocol ip list 103
snmp-server community public RO
snmp-server location Rijssen
line con 0
exec-timeout 0 0
password 7 060506324F41
login
line aux 0
line vty 0 4
password 7 13061E010803
login
no scheduler allocate
end
CiscoRAS#show run
Current configuration : 4575 bytes
version 12.1
service timestamps debug datetime
service timestamps log datetime
hostname CiscoRAS
logging buffered 4096 debugging
no logging console
enable password 7 095C5B021A0415
username GRDHKA callback-dialstring xxxxxx
username inasv callback-dialstring xxxxxx
username inarth callback-dialstring xxxxx
username inawdr callback-dialstring
username GRDHKU callback-dialstring xxxxxx
username GRDFD password 0 xxxxx
username rien callback-dialstring xxxxxx
username GRDGK callback-dialstring
username GRDTDG callback-dialstring
username GRDGT password 0 gt345
username GRDAK password 0 ak234
username ISDNBACKUP callback-dialstring xxxxxxx password 0 Wireless
modem country mica netherlands
ip subnet-zero
isdn switch-type primary-net5
isdn voice-call-failure 0
modemcap entry TAC:MSC=&F&D2S34=18000S40=10S54=456S10=50debugthismodemS71=4
controller E1 1/0
pri-group timeslots 1-31
controller E1 1/1
interface Loopback0
ip address 192.168.100.254 255.255.255.0
interface FastEthernet1/0
ip address 172.16.1.20 255.255.0.0
ip nat outside
no keepalive
duplex auto
speed auto
interface Serial1/0:15
no ip address
encapsulation ppp
dialer pool-member 1
isdn incoming-voice modem
no cdp enable
ppp callback accept
ppp authentication pap ms-chap
interface Group-Async1
no ip address
encapsulation ppp
dialer in-band
dialer pool-member 2
async mode dedicated
ppp callback accept
group-range 1 30
interface Dialer0
ip unnumbered Loopback0
ip nat inside
encapsulation ppp
dialer pool 1
dialer idle-timeout 300
dialer enable-timeout 5
dialer redial interval 5 attempts 1
dialer-group 1
peer default ip address pool inbpool
ppp callback accept
ppp chap refuse
interface Dialer1
ip address 192.168.10.3 255.255.255.0
ip address 11.1.1.1 255.255.255.0 secundary
encapsulation ppp
dialer pool 1
dialer-group 3
ppp callback accept
dialer remote-name ISDNBACKUP
interface Dialer60
ip nat inside
encapsulation ppp
dialer pool 2
dialer-group 1
ppp callback accept
ppp chap refuse
ip local pool inbpool 192.168.100.1 192.168.100.100
ip nat inside source list 101 interface FastEthernet1/0 overload
ip classless
ip route 192.168.100.0 255.255.255.0 FastEthernet1/0
no ip http server
router eirgp 100
network 11.1.1.0
network 172.16.0.0
access-list 101 permit ip 192.168.100.0 0.0.0.255 any
dialer-list 1 protocol ip permit
line con 0
line 1 30
exec-timeout 30 0
password 7 0506090B2441
absolute-timeout 120
login
modem InOut
modem autoconfigure type TAC
transport preferred none
transport input all
transport output pad v120 lapb-ta telnet rlogin udptn
line aux 0
line vty 0 4
password 7 06161A2A4F4F0B
login
end
Cisco2651#ping 192.168.10.3
Sending 5, 100-byte ICMP Echos to 192.168.10.3, timeout is 2 seconds:
1d20h: %ISDN-6-LAYER2DOWN: Layer 2 for Interface BR0/0, TEI 69 changed to down
1d20h: ISDN BR0/0: Outgoing call id = 0x8064, dsl 0
1d20h: ISDN BR0/0: Event: Call to 0548859900 at 64 Kb/s
1d20h: ISDN BR0/0: process_bri_call(): call id 0x8064, called_number 0548859900,
speed 64, call type DATA
1d20h: CCBRI_Go Fr Host InPkgInfo (Len=26) :
1d20h: 1 0 1 80 64 0 4 2 88 90 18 1 83 70 B 80 30 35 34 38 38 35 39 39 30 30
1d20h:
1d20h: CC_CHAN_GetIdleChanbri: dsl 0
1d20h: Found idle channel B1
1d20h: %ISDN-6-LAYER2UP: Layer 2 for Interface BR0/0, TEI 69 changed to up
1d20h: ISDN BR0/0: TX -> SETUP pd = 8 callref = 0x64
1d20h: Bearer Capability i = 0x8890
1d20h: Channel ID i = 0x83
1d20h: Called Party Number i = 0x80, '0548859900', Plan:Unknown, Type:Un
known
1d20h: ISDN BR0/0: RX <- CALL_PROC pd = 8 callref = 0xE4
1d20h: Channel ID i = 0x8A
1d20h: CCBRI_Go Fr L3 pkt (Len=7) :
1d20h: 2 1 64 98 18 1 8A
1d20h:
1d20h: ISDN BR0/0: LIF_EVENT: ces/callid 1/0x8064 HOST_PROCEEDING
1d20h: ISDN BR0/0: HOST_PROCEEDING
1d20h: ISDN BR0/0: HOST_MORE_INFO.
1d20h: ISDN BR0/0: RX <- CONNECT pd = 8 callref = 0xE4
1d20h: Date/Time i = 0x0208090B0631
1d20h: Connected Number i = 0x00C3
1d20h: CCBRI_Go Fr L3 pkt (Len=16) :
1d20h: 7 1 64 91 29 6 2 8 9 B 6 31 4C 2 0 C3
1d20h:
1d20h: ISDN BR0/0: LIF_EVENT: ces/callid 1/0x8064 HOST_CONNECT
1d20h: %LINK-3-UPDOWN: Interface BRI0/0:2, changed state to up
1d20h: ISDN: get_isdn_service_state(): idb 0x8114F118 bchan 3 is_isdn 1 Not a Pr
i
1d20h: BR0/0:2 PPP: Treating connection as a callout
1d20h: BR0/0:2 PPP: Phase is ESTABLISHING, Active Open [0 sess, 1 load]
1d20h: BR0/0:2 PPP: No remote authentication for call-out
1d20h: BR0/0:2 LCP: O CONFREQ [Closed] id 240 len 10
1d20h: BR0/0:2 LCP: MagicNumber 0x0DE9A864 (0x05060DE9A864)
1d20h: ISDN BR0/0: Event: Connected to 0548859900 on B2 at 64 Kb/s
1d20h: ISDN BR0/0: TX -> CONNECT_ACK pd = 8 callref = 0x64
1d20h: BR0/0:2 LCP: I CONFREQ [REQsent] id 96 len 14
1d20h: BR0/0:2 LCP: AuthProto PAP (0x0304C023)
1d20h: BR0/0:2 LCP: MagicNumber 0xBE00CC6D (0x0506BE00CC6D)
1d20h: BR0/0:2 LCP: O CONFACK [REQsent] id 96 len 14
1d20h: BR0/0:2 LCP: I CONFACK [ACKsent] id 240 len 10
1d20h: BR0/0:2 LCP: State is Open
1d20h: BR0/0:2 PPP: Phase is AUTHENTICATING, by the peer [0 sess, 1 load]
1d20h: BR0/0:2 PAP: O AUTH-REQ id 15 len 24 from "ISDNBACKUP"
1d20h: BR0/0:2 PAP: I AUTH-ACK id 15 len 5
1d20h: BR0/0:2 PPP: Phase is UP [0 sess, 1 load]
1d20h: BR0/0:2 IPCP: O CONFREQ [Closed] id 8 len 10
1d20h: BR0/0:2 IPCP: Address 192.168.10.2 (0x0306C0A80A02)
1d20h: BR0/0:2 CDPCP: O CONFREQ [Closed] id 8 len 4
1d20h: BR0/0:2 LCP: I TERMREQ [Open] id 97 len 4
1d20h: BR0/0:2 LCP: O TERMACK [Open] id 97 len 4
1d20h: BR0/0:2 IPCP: State is Closed
1d20h: BR0/0:2 CDPCP: State is Closed
1d20h: BR0/0:2 PPP: Phase is TERMINATING [0 sess, 1 load]
1d20h: ISDN BR0/0: RX <- DISCONNECT pd = 8 callref = 0xE4
1d20h: Cause i = 0x8090 - Normal call clearing
1d20h: CCBRI_Go Fr L3 pkt (Len=8) :
1d20h: 45 1 64 96 8 2 80 90
1d20h:
1d20h: ISDN BR0/0: LIF_EVENT: ces/callid 1/0x8064 HOST_DISCONNECT
1d20h: ISDN BR0/0: Event: Call to <unknown> was hung up.
1d20h: ISDN BR0/0: process_disc_ack(): call id 0x8064, ces 1, call type DATA cau
se 0x0
1d20h: %ISDN-6-CONNECT: Interface BRI0/0:2 is now connected to 0548859900
i
1d20h: %LINK-3-UPDOWN: Interface BRI0/0:2, changed state to down
1d20h: BR0/0:2 LCP: State is Closed
1d20h: BR0/0:2 PPP: Phase is DOWN [0 sess, 1 load]
1d20h: CCBRI_Go Fr Host InPkgInfo (Len=10) :
1d20h: 6 0 1 80 64 0 8 2 0 8
1d20h:
1d20h: ISDN BR0/0: TX -> RELEASE pd = 8 callref = 0x64
1d20h: ISDN BR0/0: RX <- RELEASE_COMP pd = 8 callref = 0xE4
1d20h: 5A 1 64 99 8 2 80 90
1d20h:
1d20h: ISDN BR0/0: LIF_EVENT: ces/callid 1/0x8064 HOST_DISCONNECT_ACK
i
1d20h: ISDN BR0/0: HOST_DISCONNECT_ACK: call type is DATA.
1d20h: ISDN BR0/0: Outgoing call id = 0x8065, dsl 0
1d20h: ISDN BR0/0: process_bri_call(): call id 0x8065, called_number 0548859900,
1d20h: 1 0 1 80 65 0 4 2 88 90 18 1 83 70 B 80 30 35 34 38 38 35 39 39 30 30
1d20h:
1d20h: ISDN BR0/0: TX -> SETUP pd = 8 callref = 0x65
known
1d20h: ISDN BR0/0: RX <- .CALL_PROC pd = 8 callref = 0xE5
1d20h: Channel ID i = 0x89
1d20h: 2 1 65 98 18 1 89
1d20h:
1d20h: ISDN BR0/0: LIF_EVENT: ces/callid 1/0x8065 HOST_PROCEEDING
1d20h: ISDN BR0/0: RX <- CONNECT pd = 8 callref = 0xE5
1d20h: Date/Time i = 0x0208090B0635
1d20h: 7 1 65 91 29 6 2 8 9 B 6 35 4C 2 0 C3
1d20h:
1d20h: ISDN BR0/0: LIF_EVENT: ces/callid 1/0x8065 HOST_CONNECT
1d20h: %LINK-3-UPDOWN: Interface BRI0/0:1, changed state to up
1d20h: ISDN: get_isdn_service_state(): idb 0x8114B5B4 bchan 2 is_isdn 1 Not a Pr
i
1d20h: BR0/0:1 PPP: Treating connection as a callout
1d20h: BR0/0:1 PPP: Phase is ESTABLISHING, Active Open [0 sess, 1 load]
1d20h: BR0/0:1 PPP: No remote authentication for call-out
1d20h: BR0/0:1 LCP: O CONFREQ [Closed] id 243 len 10
1d20h: BR0/0:1 LCP: MagicNumber 0x0DE9B85C (0x05060DE9B85C)
1d20h: ISDN BR0/0: Event: Connected to 0548859900 on B1 at 64 Kb/s
1d20h: ISDN BR0/0: TX -> CONNECT_ACK pd = 8 callref = 0x65
1d20h: BR0/0:1 LCP: I CONFREQ [REQsent] id 98 len 14
1d20h: BR0/0:1 LCP: AuthProto PAP (0x0304C023)
1d20h: BR0/0:1 LCP: MagicNumber 0xBE00DC68 (0x0506BE00DC68)
1d20h: BR0/0:1 LCP: O CONFACK [REQsent] id 98 len 14
1d20h: BR0/0:1 LCP: I CONFACK [ACKsent] id 243 len 10
1d20h: BR0/0:1 LCP: State is Open
1d20h: BR0/0:1 PPP: Phase is AUTHENTICATING, by the peer [0 sess, 1 load]
1d20h: BR0/0:1 PAP: O AUTH-REQ id 16 len 24 from "ISDNBACKUP"
1d20h: BR0/0:1 PAP: I AUTH-ACK id 16 len 5
1d20h: BR0/0:1 PPP: Phase is UP [0 sess, 1 load]
1d20h: BR0/0:1 IPCP: O CONFREQ [Closed] id 9 len 10
1d20h: BR0/0:1 IPCP: Address 192.168.10.2 (0x0306C0A80A02)
1d20h: BR0/0:1 CDPCP: O CONFREQ [Closed] id 9 len 4
1d20h: BR0/0:1 LCP: I TERMREQ [Open] id 99 len 4
1d20h: BR0/0:1 LCP: O TERMACK [Open] id 99 len 4
1d20h: BR0/0:1 IPCP: State is Closed
1d20h: BR0/0:1 CDPCP: State is Closed
1d20h: BR0/0:1 PPP: Phase is TERMINATING [0 sess, 1 load]
1d20h: ISDN BR0/0: RX <- DISCONNECT pd = 8 callref = 0xE5
1d20h: 45 1 65 96 8 2 80 90
1d20h:
1d20h: ISDN BR0/0: LIF_EVENT: ces/callid 1/0x8065 HOST_DISCONNECT
1d20h: ISDN BR0/0: process_disc_ack(): call id 0x8065, ces 1, call type DATA cau
se 0x0
1d20h: %ISDN-6-CONNECT: Interface BRI0/0:1 is now connected to 0548859900
i
1d20h: %LINK-3-UPDOWN: Interface BRI0/0:1, changed state to down
1d20h: BR0/0:1 LCP: State is Closed
1d20h: BR0/0:1 PPP: Phase is DOWN [0 sess, 1 load]
1d20h: 6 0 1 80 65 0 8 2 0 8
1d20h:
1d20h: ISDN BR0/0: TX -> RELEASE pd = 8 callref = 0x65
1d20h: ISDN BR0/0: RX <- RELEASE_COMP pd = 8 callref = 0xE5
1d20h: 5A 1 65 99 8 2 80 90
1d20h:
1d20h: ISDN BR0/0: LIF_EVENT: ces/callid 1/0x8065 HOST_DISCONNECT_ACK
i
1d20h: ISDN BR0/0: Outgoing call id = 0x8066, dsl 0
1d20h: ISDN BR0/0: process_bri_call(): call id 0x8066, called_number 0548859900,
1d20h: 1 0 1 80 66 0 4 2 88 90 18 1 83 70 B 80 30 35 34 38 38 35 39 39 30 30
1d20h:
1d20h: ISDN BR0/0: TX -> SETUP pd = 8 callref = 0x66
known
1d20h: ISDN BR0/0: RX <- CALL_PROC pd = 8 callref = 0xE6
1d20h: 2 1 66 98 18 1 8A
1d20h:
1d20h: ISDN BR0/0: LIF_EVENT: ces/callid 1/0x8066 HOST_PROCEEDING
Success rate is 0 percent (0/5)
Cisco2651#
1d20h: ISDN BR0/0: RX <- CONNECT pd = 8 callref = 0xE6
1d20h: Date/Time i = 0x0208090B0639
1d20h: 7 1 66 91 29 6 2 8 9 B 6 39 4C 2 0 C3
1d20h:
1d20h: ISDN BR0/0: LIF_EVENT: ces/callid 1/0x8066 HOST_CONNECT
i
1d20h: BR0/0:2 LCP: O CONFREQ [Closed] id 241 len 10
1d20h: BR0/0:2 LCP: MagicNumber 0x0DE9C813 (0x05060DE9C813)
1d20h: ISDN BR0/0: TX -> CONNECT_ACK pd = 8 callref = 0x66
1d20h: BR0/0:2 LCP: I CONFREQ [REQsent] id 100 len 14
1d20h: BR0/0:2 LCP: MagicNumber 0xBE00EC1F (0x0506BE00EC1F)
1d20h: BR0/0:2 LCP: O CONFACK [REQsent] id 100 len 14
1d20h: BR0/0:2 LCP: I CONFACK [ACKsent] id 241 len 10
1d20h: BR0/0:2 PAP: O AUTH-REQ id 16 len 24 from "ISDNBACKUP"
1d20h: BR0/0:2 PAP: I AUTH-ACK id 16 len 5
1d20h: BR0/0:2 IPCP: O CONFREQ [Closed] id 9 len 10
1d20h: BR0/0:2 CDPCP: O CONFREQ [Closed] id 9 len 4
1d20h: BR0/0:2 LCP: I TERMREQ [Open] id 101 len 4
1d20h: BR0/0:2 LCP: O TERMACK [Open] id 101 len 4
1d20h: ISDN BR0/0: RX <- DISCONNECT pd = 8 callref = 0xE6
1d20h: 45 1 66 96 8 2 80 90
1d20h:
1d20h: ISDN BR0/0: LIF_EVENT: ces/callid 1/0x8066 HOST_DISCONNECT
1d20h: ISDN BR0/0: process_disc_ack(): call id 0x8066, ces 1, call type DATA cau
se 0x0
i
1d20h: 6 0 1 80 66 0 8 2 0 8
1d20h:
1d20h: ISDN BR0/0: TX -> RELEASE pd = 8 callref = 0x66
1d20h: ISDN BR0/0: RX <- RELEASE_COMP pd = 8 callref = 0xE6
1d20h: 5A 1 66 99 8 2 80 90
1d20h:
1d20h: ISDN BR0/0: LIF_EVENT: ces/callid 1/0x8066 HOST_DISCONNECT_ACK
i
  • Other Network Infrastructure Subjects
1 REPLY
Re: problem2 dialing bri_to_pri
your authetication is not happening can u remove ppp authentication on both end and then try it out r u using a TACAS+ auth or local or a Radius???
124
