12-20-2003 09:21 AM - edited 03-02-2019 12:29 PM
Hi All,
I'm trying to load a new image on a pair of 3745 routers. I want to keep the old image in flash (as a failover), so I have copied the new image to slot0. The problem is it keeps booting to the original image. The syntax is:
boot system flash slot0:c3745-adventerprisek9-mz.123-2.T3
I have also tried this with the ".bin" extension. The register is 0x2102.
The flash card came with the router so I assume it's formatted correctly. The new image copied to slot0 without any error messages, and it shows up in "dir slot0:". This is a remote router so I couldn't see any console messages when it reloaded.
Any ideas?
Thanks, Randy
Solved! Go to Solution.
12-20-2003 10:54 PM
Hi Randy,
I guess ur router is a bit short of DRAM memory which is probably preventing the router to load new ios from flash. What is DRAM capacity of Router???
Amit
12-20-2003 10:54 PM
Hi Randy,
Amit
12-29-2003 11:14 AM
I got a solution from TAC and it was so weird I though I'd post it in case anyone else has this problem.
The solution was to reformat and erase the compact flash card TWICE. After loading the image on the third time it worked just fine. The correct command syntax is:
boot system flash slot0:filename.bin
There is a CCO page that says to use "disk0:" instead of "slot0:" when the flash card is larger than 24Mb, but this is not true for the 3745. I even had a TAC engineer tell me this, so be carefull what you believe.
Thanks, Randy
