problems displaying WS-5482 in Cisco Works
peper
Hello.
My scannario:
Cisco Works Station, Catalyst 3524 with a redundant link :
- Primary Link WS-5482 GBIC 1000BaseT module (it is represented in Cisco Works as a WS-5484= 1000BaseSX) ???
- Secondary Link WS-5484 GBIC 1000BaseSx módule.
Problem
The two Links work well but Cisco Works display the 1000BaseTx as a 1000BaseSx.
Work arround:
I had install all Cisco Works upgrades, and the bug isn´t solved.
If I access the Catalys 3548 throught CMS, Gbic modules are correctly displayed. ???
Is there any solution for this problem?
Thanks.
rmushtaq
Level 8
Level 8
When you say Cisco Works display the 1000BaseTx as 1000BaseSx, what specific application within CIsco Works are you referring to?. Is it Campus Manager?. If so what is the version?
Our software, is Cisco Works V.6. Cisco View is the aplication. It is not a Campus Manager.
Many Thanks.
