Community Member
Problems Erasing Vlan on Cat 6506 Switch
How Do i erase a Vlan that is set to a Gigabit Port on a CAt 6506 Switch
Community Member
Re: Problems Erasing Vlan on Cat 6506 Switch
You do not erase it, you assign the default VLAN ( VLAN 1 ) to this port. For example, if your Gigabit port is 7/1, your command would be :
set vlan 1 7/1
Community Member
thanks for your help. It worked
164
