Community Member
Problems in Etherchannel.
Hi all,
I had cisco 6006 layer 3 switch. I have configured channeling in the 100BaseTx ports of the switch. I have configured 7 etherchannels each having two ports. On the System side, NICs are teamed using IntelPro utility. When I test the teaming configuration in the systems, an error stating that the STP is enabled on the switch and It should be disabled. I have made portfast enabled on all the switch ports in the etherchannel. I use to get the error messages interminently and not at all times.
Is there any orderly procedure to do channeling.
Let me know about it.
Thanks in advance.
Re: Problems in Etherchannel.
Community Member
thanks shanky,
I have done all the things explained in the article except that I had did it in different order.
I have made the port channel mode on first, then spanning-tree port fast is enabled. will it have any impact on the channeling.
Clarifications please.
81
