Problems in using external database with ACS
I have configured the external database, SQL Server 2000 to connect successfully with ACS. However, ACS still cannot authenticate me successfully. I am totally lost here. I will really appreciate some help here
Some of my other problems:
1. How do I write stored procedures in my database to communicate with ACS?
Error messages: 1. No users matching, although my table is certainly not empty
Thanks for the help in advance,
Your sincerely,
bburn
Re: Problems in using external database with ACS
Thank you for replying. I tried the sample routine to create a procedure given in the sample documentation. However, it doesn't seem to work. Here's my stored procedure. What's wrong with it?Use Test
GO
if exists (select * from sysobjects where id = object_id('dbo.CSNTAuthUserPap') and sysstat & 0xf = 4)
drop procedure dbo.CSNTAuthUserPap
GO
CREATE PROCEDURE CSNTAuthUserPap
@username varchar(64), @pass varchar(255)
AS
SET NOCOUNT ON
IF EXISTS( SELECT memberID
FROM Member
WHERE memberID = @username
AND password = @pass )
SELECT 0,csntgroup,csntacctinfo,"No Error"
FROM Member
ELSE
SELECT 3,0,"odbc","ODBC Authen Error"
GO
GR
ANT EXECUTE ON dbo.CSNTAuthUserPap TO ciscosecure
GO
It keeps on throwing invalid column names. Any solutions?
Thank you.
88
