Problems installing code after flash upgrade
I just upgraded a 2600 router from 8 MB flash to 16 MB flash (that came from a working 3600). I know for a fact that the firmware for the router with the upgrade is good - I was able to upgrade a different router with no problem. However, with the new flash, the transfer of the code errors out with
File reception completed.
TFTP copy: operation terminated due to bad checksum comparison.
As best as I can tell, the flash is the same between the 2600 and 3600. Please let me know if anyone was able to successfuly do this. Thank you.
1 REPLY
Re: Problems installing code after flash upgrade
I tftp'd the image for the 2600 into the flash when it was installed in the 3600, stuck the flash into the 2600, and it boots.
94
