Problems on direct connection AUI to AUI ethernet ports
I have tried to connect directly two AUI ports of a 2514 router using a recommended cable (pins 3-5, 5-3, 10-12, 12-10; and 6 - 9 on each side).
But the ethernet interfaces goes up and immediately down, this process is repeated continuously after a few seconds. The message reason is "No Carrier".
Is there a special configuration to this port?
Is there someone, which have experience in this kind of connection?
1 REPLY
Re: Problems on direct connection AUI to AUI ethernet ports
Looks like you have a problem with the cable. Keep in mind that this is a back-to-back connection and thus you have to make a cross-over cable (connect tx on one side to the rx on the other side). Pinout for standard AUI cable:
http://www.cisco.com/univercd/cc/td/doc/product/access/acs_fix/cis2500/2501/2500ug/pin.htm#xtocid158235
101
