Community Member
Problems printing different font sizes from aix to a epson printer on 2511.
I have to setup a epson emulation dot matrix printer to be connected
from a async port on cisco 2511 access server.
This is the config.
AIX Server -> Cisco 2511 --> async port --> epson printer.
I have the following configuration on the 2511( running IOS 11.2)
printer rjr line 6 jobtimeout 600 jobtypes ascii
line 6
location "Oki IS434"
no exec
no exec-banner
modem DTR-active
terminal-type hardwired
special-character-bits 8
transport input telnet
transport output telnet
stopbits 1
flowcontrol software
This is the config on the AIX Server.
device = @as2511001
up = TRUE
host = as2511001
s_statfilter = /usr/lib/lpd/bsdshort
l_statfilter = /usr/lib/lpd/bsdlong
rq = rjr
backend = /usr/lib/lpd/rembak
With this configuration, I am able to print plain text files from the
command line.
like lp -drjr filename.txt
however, when I try to print some different fonts other than default,
the printer just prints the ascii codes.
Also, in the 2511, I get messages saying that the control lines are
Mar 1 22:20:25.670: LPD: Connection started, remote host
*Mar 1 22:20:25.686: LPD: Enter job rjr
*Mar 1 22:20:25.690: LPD rjr: data file before control
*Mar 1 22:20:25.694: LPD rjr: Read data file "dfA830test1", length
*Mar 1 22:20:26.006: LPDrjr: Read control file "cfA830test1", length
*Mar 1 22:20:26.010: LPD rjr: 7 byte line in Ctrl file "Htest1"
*Mar 1 22:20:26.014: LPD rjr: 5 byte line in Ctrl file "Proot"
*Mar 1 22:20:26.014: LPD rjr: 13 byte line in Ctrl file
*Mar 1 22:20:26.018: LPD rjr: 13 byte line in Ctrl file
*Mar 1 22:20:26.018: LPD rjr: control line ignored: "UdfA830test1"
*Mar 1 22:20:26.022: LPD rjr: 24 byte line in Ctrl file "Narpip.ksh"
tried all supported lpd config (aix, bsd,aix2)on AIX Server with the
same(or even worse, ie, no print at all) result.
Any clues on what I can do to print my custom fonts on the printer.??
Thanks in advance.
