problems routing to DMZ from outside
i have PIX Firewall with three interfaces, Problem routing to DMZ
router---PIX----DMZ another interface to to inside
i have class c addresss from my ISP i subneted into 2 network with 255.255.255.128 first rang of addressx.x.x.1- x.x.x.126 is used for outside side interface of PIX which is connected to router and i used x.x.x128 - x.x.x.254 to DMZ i can ping any host or i cannot connect to any host on DMZ
how to route between these 2 networks
thanks in advance
Re: problems routing to DMZ from outside
From which network are you trying to access the DMZ ??
From the inside or outside....
From outside, you need a conduit or access-list configured to allow connection from outside to dmz.
from outside i have the following accessl ist on the out side interface of PIX
access-list outside_access_in permit tcp any host x.x.x.130 eq smtp
access-list outside_access_in permit tcp any host x.x.x131 eq smtp
access-list outside_access_in permit udp any host x.x.x.130 eq domain
access-list outside_access_in permit udp any host x.x.x.131 eq domain
access-list outside_access_in permit icmp any any
access-list outside_access_in deny ip any any
Have you applied this access-list on the outside interface as follows?
access-group outside_access_in in interface outside
Also check if there is a static translation for the ip addresses x.x.x.130, x.x.x.131 into the local ip addresses of the servers in the DMZ. (Use static command)
This link might help!
http://www.cisco.com/en/US/products/hw/vpndevc/ps2030/products_tech_note09186a0080094aad.shtml
99
