11-03-2003 12:09 PM - edited 03-02-2019 11:26 AM
I configured clustering with my switches and using CMS. I don´t hve any problem when Haven´t configured TACACs commands, but after I add TACACs configuration, cannot access the switches with browser anymore.
I still get the first screen that ask for userID and password, but I just tried using the information I configured in the TACACS server (Cisco Secre ACS), I tried also with only telnet password, and cannot access equipments. Is there a special configuration I have to use besides http server command which already enabled?
I have these equipments with this problem:
BIBLIOTECA_SW1#sh ver
IOS (tm) C3500XL Software (C3500XL-C3H2S-M), Version 12.0(5.4)WC(1), MAINTENANCE
INTERIM SOFTWARE
Copyright (c) 1986-2001 by cisco Systems, Inc.
Compiled Tue 10-Jul-01 12:32 by devgoyal
Image text-base: 0x00003000, data-base: 0x00333CD8
ROM: Bootstrap program is C3500XL boot loader
BIBLIOTECA_SW1 uptime is 2 weeks, 4 days, 4 hours, 55 minutes
System restarted at 08:23:48 CDT Thu Oct 16 2003
System image file is "flash:c3500XL-c3h2s-mz.120-5.4.WC.1.bin"
cisco WS-C3524-XL (PowerPC403) processor (revision 0x01) with 8192K/1024K bytes
of memory.
Processor board ID FAB0544W2PZ, with hardware revision 0x00
Last reset from power-on
Processor is running Enterprise Edition Software
Cluster command switch capable
Cluster member switch capable
24 FastEthernet/IEEE 802.3 interface(s)
2 Gigabit Ethernet/IEEE 802.3 interface(s)
32K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address: 00:07:EB:29:1C:40
Motherboard assembly number: 73-3904-12
Power supply part number: 34-0851-02
Motherboard serial number: FAB0542128X
Power supply serial number: PAC053400N0
Model revision number: A0
Motherboard revision number: A0
Model number: WS-C3524-XL-EN
System serial number: FAB0544W2PZ
Configuration register is 0xF
BIBLIOTECA_SW1#
Member Switch - Biblioteca
BIBLIOTECA_SW2#sh ver
INTERIM SOFTWARE
BIBLIOTECA_SW2 uptime is 2 weeks, 4 days, 5 hours, 2 minutes
System restarted at 08:23:38 CDT Thu Oct 16 2003
of memory.
Processor board ID FAB0544W2Q1, with hardware revision 0x00
Base ethernet MAC Address: 00:07:EB:29:0F:40
Motherboard serial number: FAB054211WY
Power supply serial number: PAC0533037H
System serial number: FAB0544W2Q1
BIBLIOTECA_SW2#
11-10-2003 07:57 AM
switch(config)#ip http authentication tacacs
Check whether you have configured for the above command in the switch. This should solve the problem
