You may experience some slow load times, errors, and slight inconsistencies. We ask for your patience as we finalize the launch. Thank you.
For an introduction to the new site, click here. If you'd prefer to explore, try our beta test area to get started.
Problems using Cluster management suite and TACACS+ at same time
I configured clustering with my switches and using CMS. I don´t hve any problem when Haven´t configured TACACs commands, but after I add TACACs configuration, cannot access the switches with browser anymore.
I still get the first screen that ask for userID and password, but I just tried using the information I configured in the TACACS server (Cisco Secre ACS), I tried also with only telnet password, and cannot access equipments. Is there a special configuration I have to use besides http server command which already enabled?
I have these equipments with this problem:
BIBLIOTECA_SW1#sh ver
IOS (tm) C3500XL Software (C3500XL-C3H2S-M), Version 12.0(5.4)WC(1), MAINTENANCE
INTERIM SOFTWARE
Copyright (c) 1986-2001 by cisco Systems, Inc.
Compiled Tue 10-Jul-01 12:32 by devgoyal
Image text-base: 0x00003000, data-base: 0x00333CD8
ROM: Bootstrap program is C3500XL boot loader
BIBLIOTECA_SW1 uptime is 2 weeks, 4 days, 4 hours, 55 minutes
System restarted at 08:23:48 CDT Thu Oct 16 2003
System image file is "flash:c3500XL-c3h2s-mz.120-5.4.WC.1.bin"
cisco WS-C3524-XL (PowerPC403) processor (revision 0x01) with 8192K/1024K bytes
of memory.
Processor board ID FAB0544W2PZ, with hardware revision 0x00
Last reset from power-on
Processor is running Enterprise Edition Software
Cluster command switch capable
Cluster member switch capable
24 FastEthernet/IEEE 802.3 interface(s)
2 Gigabit Ethernet/IEEE 802.3 interface(s)
32K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address: 00:07:EB:29:1C:40
Motherboard assembly number: 73-3904-12
Power supply part number: 34-0851-02
Motherboard serial number: FAB0542128X
Power supply serial number: PAC053400N0
Model revision number: A0
Motherboard revision number: A0
Model number: WS-C3524-XL-EN
System serial number: FAB0544W2PZ
Configuration register is 0xF
BIBLIOTECA_SW1#
Member Switch - Biblioteca
BIBLIOTECA_SW2#sh ver
INTERIM SOFTWARE
BIBLIOTECA_SW2 uptime is 2 weeks, 4 days, 5 hours, 2 minutes
System restarted at 08:23:38 CDT Thu Oct 16 2003
of memory.
Processor board ID FAB0544W2Q1, with hardware revision 0x00
Base ethernet MAC Address: 00:07:EB:29:0F:40
Motherboard serial number: FAB054211WY
Power supply serial number: PAC0533037H
System serial number: FAB0544W2Q1
BIBLIOTECA_SW2#
  • Other Network Infrastructure Subjects
1 REPLY
Re: Problems using Cluster management suite and TACACS+ at same
switch(config)#ip http authentication tacacs
Check whether you have configured for the above command in the switch. This should solve the problem
316
