Community Member
Problems with 1721 and DHCP
I have enable DHCP on my 1721 but it will not seem to work The clients see not DHCP server on the LAN. Any Help? Here is my current config file.
Current configuration : 1967 bytes
version 12.4
service nagle
no service pad
service tcp-keepalives-in
service tcp-keepalives-out
service timestamps debug datetime msec localtime show-timezone
service timestamps log datetime msec localtime show-timezone
service password-encryption
hostname GreenCo_Bloomington
boot-start-marker
boot-end-marker
logging buffered 4096
enable secret 5 xxxxxxxxxxxxxxxxxxxx
no aaa new-model
clock timezone CST -6
clock summer-time CDT recurring
no ip source-route
no ip gratuitous-arps
ip cef
no ip dhcp use vrf connected
ip dhcp excluded-address 192.168.2.1 192.168.2.99
ip dhcp pool bloomington
  network 192.168.2.128 255.255.255.192
  default-router 192.168.2.1
  dns-server 208.67.222.222 208.67.220.220
  domain-name greenviewnet.local
  lease 0 0 1
no ip bootp server
ip name-server 205.171.3.65
ip name-server 205.171.2.65
ip name-server 198.6.1.4
archive
log config
  hidekeys
interface FastEthernet0
ip address 192.168.2.1 255.255.255.0
no ip redirects
no ip proxy-arp
speed auto
interface Serial1
ip address 63.232.191.150 255.255.255.252
no ip redirects
no ip proxy-arp
encapsulation ppp
interface Async1
no ip address
encapsulation slip
interface Group-Async1
physical-layer async
ip unnumbered FastEthernet0
encapsulation ppp
dialer in-band
dialer idle-timeout 600
dialer-group 1
async mode interactive
peer default ip address pool remote-access
ppp authentication chap
ip local pool remote-access 10.10.10.1
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 63.232.191.149
no ip http server
no ip http secure-server
dialer-list 1 protocol ip permit
control-plane
line con 0
line 1
password 7 xxxxxxxxxxxxxxxxxxxxxxx
login
modem InOut
transport input all
stopbits 1
speed 115200
flowcontrol hardware
line aux 0
line vty 0 4
password 7 xxxxxxxxxxxxxxxxxxxxxxxxxxx
login
line vty 5 15
login
end
Everyone's tags (1)
Community Member
Re: Problems with 1721 and DHCP
The network in your DHCP config doesn't match your LAN
Try the following instead:
  network 192.168.2.0 255.255.255.0
Community Member
I had already tried that and it makes no difference. In the case show I was just using a starting IP out of the reserved range with a /26 netmask to give a pool of only 64 IPs instead of using the whole class. Any other thoughts?
Community Member
In the dhcp config the network should match the LAN subnet
Use the command ip dhcp excluded-address to limit addresses from the scope.
To make sure the DHCP service is running. use: service dhcp command
Hall of Fame Super Gold
I agree with a-moseley's post.  Your DHCP scope is incompatible with your LAN.  I don't know what your IOS is so I'd recommend you reload your router and release/renew the IP address of the clients.
873
