Community Member
Problems with 2950 switch and console
We console into a Cisco 2950 and plug it in. We see it go through the boot process. It then comes to a screen to press return to get started. At this point pressing return does nothing. The Press Return to get started just keeps a rolling repeat about every 15 seconds. Any suggestions? Thanks.
Silver
Re: Problems with 2950 switch and console
You sure you're terminal settings are 9600-8-N-1? What terminal program are you using to access this?
Have you tried another cable? Maybe something is wrong with your TX side, not allowing input into the console, but I would not think that your message would scroll unless it was getting something from the terminal side.
Stab in the dark, but I hope it helps,
Don
Community Member
I tried new cables, and I have even interupted the boot sequence. Once I interupt it I can do different commands..? .. dir...
But when I let it go completely through the boot sequence it comes to:
Segment2 con0 is now available
Press RETURN to get started.
Pressing return does nothing....Thanks in advance for any help.
Community Member
Here is something you can try,
Use the password recovery method to "circumvent" the config. I am guessing there is something in the config which is doing this since you have proved that you can type commands in in switch: mode.
http://www.cisco.com/warp/public/474/pswdrec_2900xl.html
213
