Community Member
Problems with ADSL WIC on 2621 Router with Pac Bell DSL
I have configured an ADSL WIC card on a 2621 router with the following basic configuration:
interface ATM 0/0
ip address x.x.x.x x.x.x.x (as provide by Pac Bell)
atm vc-per-vp 256 (on by default)
no atm ilmi-keepalive
pvc 0/35 (also provided by Pac Bell)
protocol ip x.x.x.y broadcast (address of "gateway" Pac Bell gave me)
encapsulation aal5snap (they told me they are using RFCc1483)
dsl operating mode auto
no fair queue
This configuration will get the atm interface trained and I get an up/up when I do a show int atm 0/0, so layer 1 and layer 2 seems to be working. Also, when I do debug atm events, and I watch the communications it seems that the router talks gets set up correctly.
My problem is this: I cannot get layer 3 connectivity. I cannot ping the "gateway" or anything beyond it. Even if I do a default route to the address they gave me. I know the line wokrs, because when I replace the Cisco with a Cayman router and just insert the same information into their menus, I get connectivity.
I have no access lists that would be interfering either. What am I doing wrong? I have a 255.255.255.224 subnet for the static IPs they gave me, and I read in an earlier posting that someone was doubtful that it was RFC 1483...I quote "Well you need to be sure about the config of the line..If they have given you the 5 static routable ip address then its hard to belive that its just "RFC1483 Bridging"
Any help????
1 ACCEPTED SOLUTION
Re: Problems with ADSL WIC on 2621 Router with Pac Bell DSL
Pacbell generally have IRB with RFC1483 bridging OR PPPoE..So try using the config located at following url
http://www.cisco.com/warp/public/794/wicadsl_rfc_irb_nat_1.html
Here is the place which has a sample config for different line config..Pl. locate "cisco ADSL WIC" section
Tejal
Tejal
Community Member
This put me on the right track...my final configuration was similar to this:
bridge irb
interface ATM0/0
no ip address
no ip mroute-cache
atm vc-per-vp 256
atm voice aal2 aggregate-svc upspeed-number 0
pvc 0/35
dsl operating-mode auto
no fair-queue
bridge-group 1
interface BVI1
ip address x.x.x.x y.y.y.y
etc.,
etc.,
320
