Webcast-Catalyst9k
Problems with C2948G
Hi, I have the next problem with a network that has a G2948G, a 2948G-L3 (this switch makes the routing between 3 vlan's), a 4912G and a 3550.
The core is the 4912G, the others switches are attached to it in star with fiber 1000SX.
All the links are trunks with the 3 vlan's with 802.1Q.
The problem happens when I do a FTP to a server attached to the 2948G from a PC attached to the 2948G-L3 (both are in VLAN1), the speeed is very low.
If we change the server to VLAN2 for example, the speed is normal. It does work well too when the server and the PC are in the same switch no matter the VLAN when they are.
The problem seems to be in the fiber between the C2948G and C4912G, but the routing does work very well and all go through the same fiber.
I've changed the fibers, the GBIC's ,etc.
Finally I've disconnected the fiber, and with a cross cable I've attached the C2948G and the 3550. What can I do to put the fiber?
Here there are the configurations
2948G-L3
version 12.0
no service pad
hostname cpd_2948G_L3
sdm size ipx-bvi-network 32
sdm size ip-adjacency 2048
sdm size ipx-node 2048
sdm size ip-prefix 8192
sdm size ipx-network 6144
sdm size ip-mcast 3072
sdm size udp-flooding 256
sdm size l2-switching 1024
sdm autolearn
ip subnet-zero
bridge irb
interface FastEthernet47
no ip address
no ip directed-broadcast
bridge-group 1
interface FastEthernet48
no ip address
bridge-group 1
interface GigabitEthernet49
no ip address
interface GigabitEthernet49.1
encapsulation dot1Q 1 native
bridge-group 1
interface GigabitEthernet49.2
encapsulation dot1Q 2
bridge-group 2
interface GigabitEthernet49.3
encapsulation dot1Q 3
bridge-group 3
interface GigabitEthernet50
no ip address
bridge-group 1
interface BVI1
ip address x.x.x.182 255.255.255.0
interface BVI2
ip address 192.168.151.254 255.255.255.0
no ip route-cache cef
interface BVI3
ip address 192.168.152.254 255.255.255.0
ip classless
ip route 0.0.0.0 0.0.0.0 194.246.60.3
ip http server
dialer-list 1 protocol ip permit
dialer-list 1 protocol ipx permit
snmp-server community public RO
snmp-server community private RW
snmp-server enable traps snmp
snmp-server enable traps config
snmp-server enable traps entity
snmp-server enable traps bgp
bridge 1 protocol ieee
bridge 1 route ip
bridge 2 protocol ieee
bridge 2 route ip
bridge 3 protocol ieee
bridge 3 route ip
C2948G
#version 5.5(10)
#system web interface version(s)
set prompt cpd_2948G>
#system
#frame distribution method
set port channel all distribution mac both
#vtp
set vtp domain benteler
set vtp v2 enable
set vlan 1 name default type ethernet mtu 1500 said 100001 state active
set vlan 2 name red_151 type ethernet mtu 1500 said 100002 state active
set vlan 3 name red_152 type ethernet mtu 1500 said 100003 state active
set vlan 1002 name fddi-default type fddi mtu 1500 said 101002 state active
set vlan 1004 name fddinet-default type fddinet mtu 1500 said 101004 state active bridge 0x0 stp ieee
set vlan 1005 name trbrf-default type trbrf mtu 4472 said 101005 state active bridge 0xf stp ibm
set vlan 1003 name trcrf-default type trcrf mtu 4472 said 101003 state active parent 1005 ring 0xccc mode srb aremaxhop 7 stemaxhop 7 backupcrf off
#ip
set interface sc0 1 x.x.x.63/255.255.255.0 192.0.2.255
set interface sl0 down
set interface me1 down
#set boot command
set boot config-register 0x2
set boot system flash bootflash:cat4000.5-5-10.bin
#module 1 : 0-port Switching Supervisor
#module 2 : 50-port 10/100/1000 Ethernet
set udld enable 2/1-48
set trunk 2/9 on dot1q 1-1005
end
C4912G
#version 4.5(3)
set prompt cpd_4912G>
set length 24 default
set logout 20
#ip
set interface sc0 1 x.x.x.181 255.255.255.0 192.0.2.255
set interface sc0 up
set interface sl0 0.0.0.0 0.0.0.0
set interface me1 0.0.0.0 0.0.0.0 0.0.0.0
set arp agingtime 1200
set ip redirect enable
set ip unreachable enable
set ip fragmentation enable
set ip alias default 0.0.0.0
#vtp
set vtp mode server
set vtp v2 enable
set vtp pruning disable
set vtp pruneeligible 2-1000
clear vtp pruneeligible 1001-1005
#spantree
#uplinkfast groups
set spantree uplinkfast disable
#backbonefast
set spantree backbonefast disable
#vlan 1
set spantree enable 1
set spantree fwddelay 15 1
set spantree hello 2 1
set spantree maxage 20 1
set spantree priority 32768 1
#vlan 2
set spantree enable 2
set spantree fwddelay 15 2
set spantree hello 2 2
set spantree maxage 20 2
set spantree priority 32768 2
#vlan 3
set spantree enable 3
set spantree fwddelay 15 3
set spantree hello 2 3
set spantree maxage 20 3
set spantree priority 32768 3
#vlan 1003
set spantree enable 1003
et spantree fwddelay 4 1003
set spantree hello 2 1003
set spantree maxage 10 1003
set spantree priority 32768 1003
#vlan 1005
set spantree enable 1005
set spantree fwddelay 15 1005
set spantree hello 2 1005
set spantree maxage 20 1005
set spantree priority 32768 1005
#set boot command
#permit list
set ip permit disable
#protocolfilter
set protocolfilter disable
#standby ports
set standbyports disable
set module name 1
#module 2 : 12-port 1000BaseX Ethernet
set module name 2
set module enable 2
set vlan 1 2/1-12
set port channel 2/1-4 off
set port channel 2/5-8 off
set port channel 2/9-12 off
set port channel 2/1-2 on
set port channel 2/3-4 auto
set port channel 2/5-8 auto
set port channel 2/9-12 auto
set port enable 2/1-12
set port level 2/1-12 normal
set port duplex 2/1-12 full
set port trap 2/1-12 disable
set port name 2/1-12
set port security 2/1-12 disable
set port membership 2/1-12 static
set port protocol 2/1-12 ip on
set port protocol 2/1-12 ipx auto
set port negotiation 2/1-12 enable
set port flowcontrol send 2/1-12 desired
set port flowcontrol receive 2/1-12 off
set cdp enable 2/1-12
set cdp interval 2/1-12 60
set trunk 2/1 on dot1q 1-1005
set trunk 2/2 on dot1q 1-1005
set trunk 2/3 on dot1q 1-1005
set trunk 2/4 on dot1q 1-1005
set trunk 2/5 on dot1q 1-1005
set trunk 2/6 on dot1q 1-1005
set trunk 2/7 auto dot1q 1-1005
set trunk 2/8 on dot1q 1-1005
set trunk 2/10 on dot1q 1-1005
set trunk 2/11 auto dot1q 1-1005
set trunk 2/12 on dot1q 1-1005
set spantree portfast 2/1-12 disable
set spantree portcost 2/1-12 4
set spantree portpri 2/1-12 32
set spantree portvlanpri 2/1 0
set spantree portvlanpri 2/2 0
set spantree portvlanpri 2/3 0
set spantree portvlanpri 2/4 0
set spantree portvlanpri 2/5 0
set spantree portvlanpri 2/6 0
set spantree portvlanpri 2/7 0
set spantree portvlanpri 2/8 0
set spantree portvlanpri 2/9 0
set spantree portvlanpri 2/10 0
set spantree portvlanpri 2/11 0
set spantree portvlanpri 2/12 0
set spantree portvlancost 2/1 cost 18
set spantree portvlancost 2/2 cost 18
set spantree portvlancost 2/3 cost 18
set spantree portvlancost 2/4 cost 18
set spantree portvlancost 2/5 cost 18
set spantree portvlancost 2/6 cost 18
set spantree portvlancost 2/7 cost 18
set spantree portvlancost 2/8 cost 18
set spantree portvlancost 2/9 cost 18
set spantree portvlancost 2/10 cost 18
set spantree portvlancost 2/11 cost 18
set spantree portvlancost 2/12 cost 18
#switch port analyzer
!set span 1 1/1 both inpkts disable
set span disable
#cam
set cam agingtime 1-3,1003,1005 300
end
C3550
Current configuration : 1568 bytes
version 12.1
no service pad
service timestamps debug uptime
service timestamps log uptime
hostname cpd_3550
enable secret xxxxxxxx!
ip subnet-zero
no ip finger
interface Port-channel1
switchport mode trunk
no ip address
snmp trap link-status
interface GigabitEthernet0/7
no ip address
interface GigabitEthernet0/8
no ip address
interface GigabitEthernet0/11
no ip address
channel-group 1 mode on
interface GigabitEthernet0/12
switchport mode dynamic auto
no ip address
interface Vlan1
ip address x.x.x.232 255.255.255.0
end
Many thanks in advance
1 REPLY
Re: Problems with C2948G
I need some more information:
1.) Whether this problem happens only when doing FTP?
2.) How about accessing servers in other VALNS?
3.) How is the ping response? Is it continious?
4.) To which port to which port between 2948G-l3 and 4900 is the connection?
102
