Problems with Ciscoview 5.3
Under Ciscoview (CWW 6.0) i can't modify the RW SNMP community when I try to reach a device. The field is grayed and I have no possibility to modifie it.
Does someone know how to solve this problem ??
Red
Re: Problems with Ciscoview 5.3
Could it be that you are not authorized to modify the settings?
I dont think so , I have logged in ciscoview with an administrator profile (full rights) ...
Blue
If you're logged in CV as admin, then you should be able to do anything, as admin as full rights to modify settings including RW/RO strings
Under CiscoView 5.3, after typing the correct read and write communities, I am able to modify RW community. I guess grey might not mean you can not modify. Have you tried to modify the field. Like to hear your further news.
105
