Webcast-Catalyst9k
Problems with CNS NFC 4.0 on Linux 7.2
I have installed CNS NFC on Linux platform but I'm having serious problems in managing it.
Infact following documentation I use commands like
$ $NFC_DIR
to see if installation went fine but I received always the answer that the command isn't supported.
I'm very new with Linux but is there anybody that could support me ?
Marco
Silver
Re: Problems with CNS NFC 4.0 on Linux 7.2
I guess, there could be something wrong with the procedure you would have followed for the installation. The procedure to install the CNS NFC on the Linux platform is being documented as below. Please refer to it.
Installing on a Linux Platform
http://www.cisco.com/en/US/products/sw/netmgtsw/ps1964/prod_installation_guide09186a0080115483.html#1037975
Hope this helps.
To confirm your idea I effectively missed to set the env variable.
Thanks for the reply
Marco
87
