Community Member
Problems with CW2K install.
Hello.
I put in CD ONE (4th Edition) and selected the "typical install". About half way thru the install, I get the following error message...
DNS check has failed for one of the following reasons:
* Your DNS is not working.
* Your DNS is slow.
* The hostname of this server is not in DNS.
How do I resolve this??
I can get to the web just fine. I can also perform nslookup's just fine. So, I assume DNS is
working.
Any thoughts??
1 REPLY
Community Member
Re: Problems with CW2K install.
Does the machine you are installing from have a DNS entry? I ran into a similar problem where the domain of the machine I was installing CW2K was incorrect (ccc.gte.com instead of cc.gte.com).
Good luck.
Steve
110
