problems with distributed cef
Is anyone aware of any known bugs with dCef on a 7500 with 12.3.7T? It was working fine on 12.2.21a. After the upgrade, the NMS system started reporting service failurs on all remote servers. Everything was pingable. After disabling dCef, the serverices started responding. The remote sites all have 2651XM routers with IP CEF and auto QoS enabled.
Thanks as usual,
Patrick
1 REPLY
Re: problems with distributed cef
I also had a problem with distributed CEF on my 7500 running 12.2(8)T10. There are 3 VIP blades in the 7500, one with 2 FE cards and one with a single FE card. The other VIP has a serial card for 8 ports with my two Internet providers attached to this card. When I enable dCEF I loose Internet connectivity to these providers.
There appears to be a bug or a configuration missing with dCEF and the 7500 with certain versions of the IOS. I would be curios to know a resolution to the problem.
Jeff
218
