Community Member
Problems with DLSW when moving from Token Ring hub to a switch
We have recently encountered problems with our service provider router when we moved its interface from a Token Ring Hub to a switched Token Ring connection.
IP connectivity was fine, but the router had problems establishing DLSW sessions with its remote peers.
Could anyone explain why this occurred and how we could avoid it in the future.
1 REPLY
Gold
Re: Problems with DLSW when moving from Token Ring hub to a swit
Double check the ring configuration parameters, espically if you are using the
39xx t/r switch. It does the ring number in hex.
88
