Problems with DVTI and Easy-vpn
wim_depauw
I created a test setup with Easy-vpn and DVTI between 2 * 3725.  Although my tunnel comes up  I can't send  a ping from the hub to the spoke . I did some troubleshooting and noticed the following:
When I ping from the server at the hub site my packet isn't encrypted  and  I receive an error message a the spoke site that I received an unencrypted packet which should have been encrypted.
When I ping from the client at the spoke to the server   , the packet is encrypted in the spoke and decrypted in the hub router.
So the most logical conclusion is that there is something wrong at the hub but I can't find out what the problem is....
Hereby the config of both routers
HUB router
Current configuration : 1936 bytes
version 12.4
hostname R2
boot-start-marker
boot-end-marker
aaa new-model
aaa authentication login default local
aaa authorization network default local
aaa session-id common
memory-size iomem 5
ip cef
username cisco privilege 15 password 0 cisco
archive
log config
  hidekeys
crypto isakmp policy 1
encr 3des
authentication pre-share
group 2
crypto isakmp key cisco123 address 0.0.0.0 0.0.0.0
crypto isakmp keepalive 10
crypto isakmp client configuration group cisco
key cisco
dns 6.0.0.2
wins 7.0.0.1
domain cisco.com
acl 101
crypto isakmp profile vi
   match identity group cisco
   isakmp authorization list default
crypto ipsec transform-set set esp-3des esp-sha-hmac
crypto ipsec profile vi
set transform-set set
set isakmp-profile vi
crypto dynamic-map dynmap 1
crypto map dynmap isakmp authorization list default
crypto map dynmap client configuration address respond
crypto map dynmap 1 ipsec-isakmp dynamic dynmap
interface FastEthernet0/0
ip address 10.149.0.221 255.255.255.0
duplex auto
speed auto
interface FastEthernet0/1
ip address 192.168.2.1 255.255.255.0
duplex auto
speed auto
interface Virtual-Template1 type tunnel
ip unnumbered FastEthernet0/0
tunnel source FastEthernet0/0
tunnel mode ipsec ipv4
tunnel protection ipsec profile vi
ip local pool dpool 5.0.0.1 5.0.0.3
ip local pool dynpool 10.149.0.1 10.149.0.100
ip forward-protocol nd
ip route 192.168.1.2 255.255.255.255 10.149.0.220
ip http server
no ip http secure-server
access-list 101 permit ip 192.168.2.0 0.0.0.255 any log
access-list 101 permit ip any any
control-plane
line con 0
line aux 0
line vty 0 4
end
Spoke router
R1# sho run
Building configuration...
Current configuration : 1228 bytes
version 12.4
hostname R1
boot-start-marker
boot-end-marker
no aaa new-model
memory-size iomem 5
ip cef
archive
log config
  hidekeys
crypto ipsec client ezvpn ez
connect auto
group cisco key cisco
local-address FastEthernet0/0
mode network-extension
peer 10.149.0.221
virtual-interface 1
xauth userid mode interactive
ip address 10.149.0.220 255.255.255.0
duplex auto
speed auto
ip address 192.168.1.4 255.255.255.0
duplex auto
speed auto
crypto ipsec client ezvpn ez inside
no ip address
ip route 192.168.2.2 255.255.255.255 10.149.0.221
ip http server
control-plane
line con 0
line aux 0
line vty 0 4
login
end
HUB Troubleshooting
R2#sho crypto session det
Crypto session current status
Code: C - IKE Configuration mode, D - Dead Peer Detection
K - Keepalives, N - NAT-traversal, X - IKE Extended Authentication
F - IKE Fragmentation
Interface: Virtual-Access2
Profile: vi
Group: cisco
Uptime: 00:46:53
Session status: UP-ACTIVE
Peer: 10.149.0.220 port 500 fvrf: (none) ivrf: (none)
      Phase1_id: cisco
      Desc: (none)
  IKE SA: local 10.149.0.221/500 remote 10.149.0.220/500 Active
          Capabilities:CD connid:1007 lifetime:23:13:05
  IPSEC FLOW: permit ip 0.0.0.0/0.0.0.0 192.168.1.0/255.255.255.0
        Active SAs: 2, origin: crypto map
        Inbound:  #pkts dec'ed 10 drop 0 life (KB/Sec) 4604343/786
        Outbound: #pkts enc'ed 0 drop 0 life (KB/Sec) 4604345/786
Spoke troubleshooting
R1#sho crypto session det
Interface: FastEthernet0/0
Uptime: 00:27:11
Peer: 10.149.0.221 port 500 fvrf: (none) ivrf: (none)
      Phase1_id: 10.149.0.221
      Desc: (none)
  IKE SA: local 10.149.0.220/500 remote 10.149.0.221/500 Active
          Capabilities:CD connid:1007 lifetime:23:32:23
  IPSEC FLOW: permit ip 192.168.1.0/255.255.255.0 0.0.0.0/0.0.0.0
        Inbound:  #pkts dec'ed 0 drop 0 life (KB/Sec) 4514884/1957
        Outbound: #pkts enc'ed 10 drop 0 life (KB/Sec) 4514882/1957
0 Replies 0
