10-03-2001 12:42 AM - edited 03-01-2019 06:48 PM
I have problems with 2 routers 801 using HSRP on an isdn connection. Starts two routers well using every router one B-Channel but every 20 Minutes Aprox. the routers change to the other B-Channel. Know someone whats the possible problem with this.
Thanks.
10-09-2001 07:04 PM
Since there has been no response to your post, it appears to be either too complex or too rare an issue for other forum members to assist you. If you don't get a suitable response to your post, you may wish to review our resources at the online Technical Assistance Center (http://www.cisco.com/tac) or speak with a TAC engineer. You can open a TAC case online at http://www.cisco.com/tac/caseopen
If anyone else in the forum has some advice, please reply to this thread.
Thank you for posting.
10-12-2001 06:05 AM
Your question is not clear.
The HSRP is used to provide redundancy to the access layer devices.
Would you like to clear the requirement
10-12-2001 12:55 PM
I think you mis-type the question.. Is not clear. Can you make a more clear question?
