Community Member
Problems with IOS upgrade 3750
Scenario: The customer has two 3750 switches and for further redundancy + speed they decided to use the stackwise tech.
I was asked to install the stack wise cables so what I did was
Stack port 1 on Switch1 > stack port 2 on Swtich2
stack port 2 on Switch1 > stack port 1 on Switch2
restarted both switches to configure them from scratch i.e. cluster + ip and etc switch 2 was in a hung state so decided to upgrade the IOS on switch 2 as it did not match switch 1.
I got my hands on a tar file for this switch and like a idiot "copy tftp flash" the tar to the flash instead of following the follwoing command :
archive download-sw /leave-old-sw tftp://
The old IOS was erased by me and here I am stcuk with the 3750 on the promt where it sasy
I can barely run any commands on this mode.
What I need to do is install/ extract the tar file as it comes up with a message saying no boot file system found etc...
Can anyone pelase advise.
Now I will need to two things from any expert
1) How to fix this IOS issue I caused which is embarassing
2) Did I patch the stackwise cables correctly ?
please respond any help will be greatly aprpeciated.
Hall of Fame Super Bronze
