Community Member
Problems with IOS upgrade 3750
Scenario: Te customer has two 3750 switches and for further redundancy + speed they decided to use the stackwise tech.
I was asked to install the stack wise cables so waht I did was
port 1 on Switch1 > port 2 on Swtich2
port 2 on Switch1 > port 1 on Switch2
restarted both switches to configure them from scratch i.e. cluster + ip and etc switch 2 was in a hung state so decided to upgrade the IOS on switch 2 as it did not match switch 1.
I got my hands on a tar file for this switch and like a idiot "copy tftp flash" the tar to the flash instead of following the follwoing command :
http://www.cisco.com/en/US/products/hw/switches/ps5023/products_configuration_example09186a00804799d7.shtml
archive download-sw /leave-old-sw tftp://11.11.11.11/c3750-i5-tar.122-20.SE.tar
The old IOS was erased by me and here I am stcuk with the 3750 on the promt where it sasy
switch:
I can barely run any commands on this mode.
What I need to do is install/ extract the tar file as it comes up with a message saying no boot file system found etc...
Can anyone pelase advise.
Now I will need to two things from any expert
1) How to fix this IOS issue I caused which is embarassing
2) Did I patch the stackwise cables correctly ?
please respond any help will be greatly aprpeciated.
cheers
AJ
Hall of Fame Super Bronze
Re: Problems with IOS upgrade 3750
Responding your first question:
You can transfer a new IOS to this switch by using XMODEM or TFTPdnld
Please check these links for either method.
http://www.cisco.com/en/US/products/hw/routers/ps221/products_configuration_guide_chapter09186a008007cd0e.html
http://www.cisco.com/warp/public/130/xmodem_generic.html
Your second question:
The cables are connected correctly.
Please rate helpful posts.
Community Member
EdisonOrtiz,
Thnak you for responding it is indeed kind of you.
Let me elaborate a little more on this.
The problem is I dont even get into the rommon mode to use the links above..
All I get with a prompt which the rotuer is switched on is
switch:
I surely tried the xmodem command in that mode and it seems to not work.
So is there a way I can change the "configure register" from the prompt I am in currently I dont even know what that prompt is called to be honest??
Am I being blind or am I looking for spoon feeding which is neither the case trust me...
I think I am under a lot of pressure to get that switch working as all the servers redundant cables were plugged into that switch.
Any help will be greatly apprecaited.
cheers
AJ
If you type
What commands are available to you ?
Community Member
If memory serves me right
does not work in that mode
neither does help
all I get is
switch:
Community Member
let me add further to this
I think I did run the command
dir flash:
and it list the .tar file only in the flash whcih is clear the result of my wrong doing.
The switch is not with me as it is onsite but I wsih I could have connected to it right now and given you the output whcih I can do tommorow if it helps.
cheers
AJ
You need the .bin file as well. That's your IOS image.
EDIT: I see you went with the archive approach, nothing wrong with that but I usually download the BIN and go with the copy tftp flash :)
Community Member
I completely agree should have done that but the customer was a novice to cisco switches and required a funky web int so I decided to go down that route and in haste messed the whole thing up :(
I agree the commanf you have suggested but I think you will need that output when the switch starts which will enable any of the experts to help me..
So I will get back to you tommorow once I have access to the switch once again.
cheers
AJ
Community Member
As promised.
switch:
Base ethernet MAC Address: 00:18:19:60:81:00
Xmodem file system is available.
The password-recovery mechanism is enabled.
Initializing Flash..
*** some text missing *****
flashfs[0]: 0 orphaned files, 0 orphaned directories
flashfs[0]: Total bytes: 15998976
flashfs[0]: Bytes used: 7837184
flashfs[0]: Bytes available: 8161792
flashfs[0]: flashfs fsck took 9 seconds.
...done Initializing Flash.
Boot Sector Filesystem (bs) installed, fsid: 3
done.
Loading "flash:c3750-ipbase-mz.122-25.SEB4/c3750-ipbase-mz.122-25.SEB4.bin"...fl
ash:c3750-ipbase-mz.122-25.SEB4/c3750-ipbase-mz.122-25.SEB4.bin: no such file or
directory
Error loading "flash:c3750-ipbase-mz.122-25.SEB4/c3750-ipbase-mz.122-25.SEB4.bin
Interrupt within 5 seconds to abort boot process.
Boot process failed...
The system is unable to boot automatically. The BOOT
environment variable needs to be set to a bootable
image.
switch:
switch: dir flah:
unable to stat flah:/: no such device
switch: dir flash:
Directory of flash:/
2 -rwx 7834112 c3750-ipbasek9-tar.122-25.SEB.tar
3 -rwx 1493 config.text
4 -rwx 5 private-config.text
8161792 bytes available (7837184 bytes used)
switch: ?
? -- Present list of available commands
boot -- Load and boot an executable image
cat -- Concatenate (type) file(s)
copy -- Copy a file
delete -- Delete file(s)
dir -- List files in directories
flash_init -- Initialize flash filesystem(s)
format -- Format a filesystem
fsck -- Check filesystem consistency
help -- Present list of available commands
load_helper -- Load and initialize a helper image
memory -- Present memory heap utilization information
mkdir -- Create dir(s)
more -- Concatenate (display) file(s)
rename -- Rename a file
reset -- Reset the system
rmdir -- Delete empty dir(s)
set -- Set or display environment variables
set_bs -- Set attributes on a boot sector filesystem
set_param -- Set system parameters in flash
sleep -- Pause (sleep) for a specified number of seconds
trap -- Cause a software breakpoint to occur
type -- Concatenate (type) file(s)
unset -- Unset one or more environment variables
version -- Display boot loader version
Community Member
As mentioned earlier I dont even see the XMODEM command listed under the help.
can I not extract that tar file which is already in the flash?
or simply erase it and than reboot the switch?
than I might get a different prompt?
Please advise.
cheers
AJ
AJ,
Reboot the device and perform the CRTL+BREAK sequence to get into ROM Mode and then follow the steps from this URL (XModem or TFTPDLND).
Make sure to download a .bin file instead of a .tar and also delete the .tar in order to create more space in the flash.
Good luck.
Hi graeme,
Try the following commands and check
switch: flash_init
switch: load_helper
switch: boot
Narayan
Narayan,
He doesn't have a valid image to boot from ...
Community Member
Thank you both for responding to the post much appreciated.
I have tried the break sequence .i.e ctrl < break >
it refuses to work
all I get is this
switch: < AJ : powered off >
Initializing Flash...
flashfs[0]: 0 files, 1 directories
flashfs[0]: Bytes used: 1024
flashfs[0]: Bytes available: 15997952
flashfs[0]: flashfs fsck took 8 seconds.
done.
directory
image.
switch: ?
If there is a another alternative please advise as the engineer onsite has just left for the day as well and that means I will have to wait until tommrow if he can again power cycle it for me.
Thank you once again so much for this help.
cheers
AJ
The sequence may vary depending upon the workstation you are running.
Read this link for various ways of ctrl break
http://www.cisco.com/en/US/products/hw/routers/ps133/products_tech_note09186a0080174a34.shtml
686
