Problems with Novell and LRE ???
i have some Workstations using the Novell Client which are connected via LRE with a Novell Server. My Problem is that the Network speed on this workstation over this LRE connection is very low (<160kbytes/s). I have found out the speed by connecting via FTP to a FTP Server with a networkspeedtest program. If i use my notebook (without Novell Client) i got a speed of >330Kbyte/s (Profile LRE-5). And if i connect one of the Workstations with Novell Client behind the LRE (10Mbit Network) the workstation works with the same speed as my notebook (>800kbyte/s). So why are the PC's with Novell Client so much slower if they are behind a LRE Connection? The Networkdevices in the LRE Connection is a 575CPE connected to a 10Mbit HUB on the side with Workstations having these Problems, and a 2924LRE on the other side. Is this a Novell Problem. Does somebody know a fix for this Problem or a workaround?
Best Regards,
Nikolaus Isele
Re: Problems with Novell and LRE ???
Hi Nikolaus, my field-technicans have reported neraly the same problem with Novell IPX and LRE. Up to now, we've also no solution nor workaround.
We use Novell Netware 3.1x and as well Netware 3.2. The IP access over the LRE seems to be ok, nearly 8MBit/s (tested with Fluke test equipment), but the results with IPX seems to be bad, more than 100 times (profile LRE-10). kind regards Harald Krenz
Hi Harald, mabe we should work together on this Problem. Please email me your email address and i will contact you.
Best regards,
Nikolaus Isele
Sorry, i forgot my email.... nikolaus.isele@infraserv.com
Nikolaus Isele
203
