Problems With QoS & Bandwidth Shaping
Have 50 remote offices(56k, 128k, 256k connections) connecting to host location back at the corp. office.
Need Telnet traffic
(Reflection Software Package telneting to a VAX system at corp office)
I have tried using Priority Queuing but when I run a test
(downloading 150 MB file), the telnet sessions slow to almost a halt.
Listed below is the config for the host router located at the corp. office & the config for the remote office.
Any help would be grateful.
HOST
interface Serial0/0
description FMS:58495467 NUA:3871800032 TERMS:ekrgmd92bd4/20030
bandwidth 1536
no ip address
encapsulation frame-relay
no fair-queue
service-module t1 timeslots 1-24
frame-relay traffic-shaping
frame-relay lmi-type ansi
interface Serial0/0.40 point-to-point
description PVC to Folcroft
ip address 172.17.1.158 255.255.255.252
ip access-group 101 in
delay 20000
frame-relay class 128
frame-relay interface-dlci 30
interface Serial0/1.40 point-to-point
ip address 172.18.1.158 255.255.255.252
map-class frame-relay 128
no frame-relay adaptive-shaping
frame-relay cir 128000
frame-relay bc 16000
frame-relay be 0
frame-relay mincir 128000
REMOTE
version 12.1
no service single-slot-reload-enable
service timestamps debug uptime
service timestamps log uptime
hostname pilot-air-folcroft
logging rate-limit console 10 except errors
enable secret 5
enable password 7
memory-size iomem 25
ip subnet-zero
no ip finger
no ip domain-lookup
ip domain-name pilotair.com
ip name-server 172.16.2.1
ip name-server 172.16.2.2
ip name-server 172.16.2.3
no ip dhcp conflict logging
ip dhcp excluded-address 172.10.1.1 172.10.1.30
ip dhcp pool 0
network 172.10.0.0 255.255.0.0
default-router 172.10.1.1
dns-server 172.16.2.1 172.16.2.2 172.16.2.3
interface FastEthernet0
ip address 172.10.1.1 255.255.0.0
speed auto
interface Serial0
description FMS:58495549 NUA:3832300992 TERMS:REL3/20145
bandwidth 128
no ip address
no fair-queue
frame-relay class pq
interface Serial0.1 point-to-point
description PVC to Lima s0/0.40 DLCI 30
ip address 172.17.1.157 255.255.255.252
delay 20000
interface Serial0.2 point-to-point
description PVC to Lima s0/1.40 DLCI 30
ip address 172.18.1.157 255.255.255.252
frame-relay interface-dlci 31
router eigrp 1
network 172.10.0.0
network 172.16.0.0
network 172.17.0.0
network 172.18.0.0
auto-summary
no eigrp log-neighbor-changes
ip classless
ip route 0.0.0.0 0.0.0.0 172.19.1.254
ip http server
map-class frame-relay pq
frame-relay priority-group 1
access-list 100 permit tcp any any eq telnet
access-list 102 permit tcp any any eq ftp-data
priority-list 1 protocol ip high list 100
priority-list 1 protocol ip low list 102
priority-list 1 protocol ip medium list 101
snmp-server community RW
line con 0
password 7
login
transport input none
line aux 0
password 7
line vty 0 4
password 7
login
no scheduler allocate
end
Re: Problems With QoS & Bandwidth Shaping
#1 You have priority list 1 defined but you do not have any interfaces configured to use it.
#2 You should probably prioritize the host side of the link also.
When I place the "service-policy output policy1" under interface serial0 the router accepts the line put when I do a sh running-config the statement is not there.
Running IOS 12.(4)T1
Enter this command into the interface config of the interface(s) you want to use this priority queue.
Sorry use: priority-group 1
267
