problems with upgrade from 4th to 5th ed of lms
Does anyone have any information as to what this errors means?
An error occurred during the move data processor: -105
Component: cdone
  • Other Network Infrastructure Subjects
Re: problems with upgrade from 4th to 5th ed of lms
Take a look at this from the CCO Bug Tool: CSCdx87041
Symptom
CD-ONE 5th edition install stops.
Condition
While installing CDONE 5th edition in a machine which has its CPU in slots
other than zero (0), the install terminates abnormally.
To verify if one is running into this, issue the following command:
psrinfo
If it returns a value other than zero (0), then the installation
of cd1 edition 5 will termintate abruptly.
Workaround
1. Copy the image from CDONE CD to a local directory.
2. Go to the directory, open setup-lib.sh in vi.
3. Replace line 1752 by the following :
Ultr=`psrinfo -v | grep -i "operates at" | head -1 | cut -c37-39`
4. Then run setup.sh from that directory.
5. Repeat the same procedure for other Ciscoworks2000 packages (RME 3.4,
Campus Manager 3.2, etc.)
Hope this helps.
Scott
Thanks for the reply but the problem is on a windows based system.
71
