procesess CPU running high on 7513
I have 2 7513 in my core ,my procsess cpu is running high on one 7513 and on other its runing low , processing switching is enabled on interface,this started happening when we replaced our catalyst 5509 with a 6509 , and 6509 is not doing any layer 3.when i tyed sh process cpu , the highest process is 15% by IP input .
Before we replaced it was running at 11% now its almost 60%
Can any one suggest me a solution .
Thanks In advance
Silver
Re: procesess CPU running high on 7513
you are procees switching all your traffic trun on ip route-cache or ip cef on all the interface this should drop the CPU and the IP INPUT process.
This worked thanks for your answer but ,now its only using 30% of the process
But ididnot use ip cef whats it does, can me tell in detail or mail me a link.
thanks once again
84
