Protocoll problems, may be. Need Help!!!
I have 2 Cisco 2600 which are connected via serial (Hardware: PowerQuicc) Interfaces. They have a DSU-Modem with a t1 Connection. I testet Hardware-Loops on both sites going over the hole line and all of them worked fine. Both interfaces are sending HDLC packetes, but thy doesn't get any Input. So I doesn't know where the Problems are! the Line is testet without errors, and a protokoll is not running.
May be some of you can help me......
Bronze
Re: Protocoll problems, may be. Need Help!!!
So you're saying that the Layer 2 should be o.k?
Can you test if cdp ist working fine?
Just give on both sides on the serial interfaces "cdp enable".
And then you can check with "show cdp neighbors".....do you see any neighbor then?
Roger
Layer 2 isn't ok, but why??
CDP is enabled, but not working!!
Layer2 is ReqSent or Listen
Silver
if l2 status is reqsent , then the encap on one side is set to ppp
ups sorry, i had ppp on both siedes configured, but that also wasn't working!
Actual HDLC is configured and a debug shows that HDLC-packages were send but without a response....
Silver
What is the set up on both ends ?
internal or external CSU ?
router and csu configs?
look at a sh ver and make sure you do not have this t1 plugged in to an async interface , these serial interfaces can only support up to 128 KB .
external CSU
on the interface is only ip address and encap configured
I don't know the configuration of the csu, but it shoul be correct!!
the t1 is plugged into the csu-Modem and this goes out with a x25 to the router into the serial PowerQuicc
"Dte V.35 TX and RX clocks detectet" on both sites
Silver
when you do a sh ver does it show async interfaces ?
no the sh ver only shows
--- 3 serial network interface(s)
--- 2 t1 Chanelized pri port
but my line is not connectet to one of the t1!!!
Silver
your t1 is connected to a serial interface or a chanelized t1 interface ?
the t1 from my Provider is going to Modem (CSU) and this is connected to the (standard) serial port on my router NOT to the T1 Interface
Silver
do you have access to both CSU's ? are they set for ESF B8ZS ?
What can the provider loop ?
If they give you a loop on towards one of your routers do you see the interface g up up (looped) ? you should see this .
i don't have have access to the csu's
and my provider gave me loops, and i saw them all good and with no errors or crc's
as far i know framing is not B8ZS because of the provider standart, but this should not the problem. My Provider made an end-to-end test with optimal results!
Silver
When they gave you loops you saw the interface go up up (looped) ?
What is the config for the serial interface on each side .
Yes the interfaces went up up(looped), and a ping test showed now errors or CrC's. So the line from my Provider seems to be good!
And on the Interface is only an IP-Address and an encapsulation configured
Silver
What about when the provider gave you a loop from the same place in the other direction ? What happened to that interface ? Can you past in a sh interface from both ends ?
Try using HDLC as encapsulation. I had the same problem once, the moment I changed them to HDLC, the link came up.
Actual i'm using HDLC but i also tried PPP both aren't working!
My Provider gave me Loops in ervery direction and at both ends, all of them were fine!
Actual i'm switched over to an old cicuit so i have no "sh int" at the moment.
But may be this helps:
the log shows two lines wich confused me
*Mar 2 02:45:58.788: Serial0/0: attempting to restart
*Mar 2 02:45:58.788: PowerQUICC(0/0): DCD is up.
Silver
Have the person who has access to the CSU give you a DTE loop . This loops the DSU back towards the router . When your interface goes up up looped, ping yourself.
i had done this and the statisiks showed no errors or crc's
Silver
Can you past in a sh interface and the config of the serial interfaces from both sides .
OK You are using HDLC. Are you using keepalives at both ends? Are the keepalive timers set to the same value? Are the interfaces 'up' and 'up'? Are all of the control leads 'up'? When the answer to all of these questions is "yes", you are ready to test. Also, check to see if the T1 line is reversed at some point (transmit and receive reversal). When a T1 line is reversed, it won't work end to end but will work great to a loop at certain points in the circuit.
Go to one end. Loop the local DSU back toward the router. Is the interface 'up up (looped)'? Good. Release the loopback.
Loop the local CSU back toward the router. Is the interface 'up up (looped)'? Good. Release the loopback.
Remove the T1 line frome the CSU and put in a looping plug. Is the interface 'up up (looped)'? Good. Remove the plug and reinsert the T1 line.
Remove the remote T1 line from the remote CSU and loop the T1 back toward the local end. This step may or may not work depending on the loss on the T1 to that point. Is the local interface 'up up (looped)'? Good. Remove the loopback and reinsert the T1 in the CSU.
Loop the remote CSU back toward the local end. Is the local interface 'up up (looped)'? Good. Release the loopback.
Loop the remote DSU back toward the local end. Is the local interface 'up up (looped)'? Good. Release the loopback.
Repeat all of the tests from the other end. If all of these tests work, you have proven that the line, CSU/DSUs, cabling and routers are good. If they still won't talk to eachother, let me know and I will try to help some more.
Another thing. As with all trouble shooting, keep a log of the tests and the results. If you are still having problems, post the log. Good hunting!!!
Hi!
When your SP loops toward you, how are yo assuming the link is OK??
with just #sh int ser, you are not able to see much info.
When loops toward you, put HDLC encaps. and make an extended ping with the packet size of 1500 (kind of ethernet), and use these data patterns:
0X0000
0X4040
OXFFFF
On every loop, clear the counters, and after every ping test, check the serial, it may be present on this case CRCs, interfase resets or something...these data patterns helps you to identyfing clocking issues, electrical problems, jitter, etc..
Please let me know if this tests helped you to find out more info.
Silver
You may want to have the config of the CSU's checked to ensure that one of the units is set to provide clock and the other is set to receive clock.
It seems connectivity is present which you have verified by using local and remote loopback test. Moeover serial line and protocol both are up. Now the left possibilty is, not getting Tx and Rx signals at correct pins. Try after Interchage Tx and Rx on serial line. Ensure encapsulation at both side is same- no matter whether PPP or HDLC.
---ejaj
Sorry - I clicked the wrong spot to reply to you and my reply may have been missed. If you are still seeking help, look at my response above (from 3/31/03). If I can help more, let me know.
Thank you all for your help, the problem was a wrong confuduration on one DSU.
It's very confusing to me why there is a strange configuration like CRC of and timeslots 1-24.
How ever i'm glad that the line is working now!!
126
