07-10-2002 12:57 PM - edited 03-01-2019 11:47 PM
Is it possible to get the serial numbers of a PSU, from say a 6509 by using remote managment, lets say, by SNMP, telnet, using ciscoworks, etc ? Ciscoworks isn't bad at inventory managment, but swapping out faulty PSU's just means we still have an administrative burden.
07-10-2002 01:27 PM
No. The CLI command on the 6K does not list the PSUs serial#. CW2K won't show it either in the Detailed Device report for the reason just mentioned earlier. For CW2K, one alternate could be to use the device User Fields 1 thru 4 and manully populate these numbers. Then create your own custom reports and run them against these fields.
07-18-2002 11:21 PM
Thanks for your time in replying.
