ian
Public IP through NAT device
I want to be able to give a server on the network a public routable IP and not a private natted IP. I thought I was on the right track here, but it didn't work. I am obviously missing something.
I have the following config:
interface FastEthernet0
ip address a.b.c.d 255.255.255.252 secondary
ip address 192.168.10.1 255.255.255.0
ip nat inside
speed auto
interface Serial0
ip address w.x.y.z 255.255.255.252
ip nat outside
ip nat inside source list 2 interface Serial0 overload
ip classless
ip route 0.0.0.0 0.0.0.0 66.178.174.73
no ip http server
access-list 2 permit 192.168.10.0 0.0.0.255
a.b.c.d is the public IP to be on the inside network.
w.x.y.z is the global IP address.
I am using 192.168.10.0 as the private network.
Hall of Fame Super Bronze
Re: Public IP through NAT device
Can you ping the Fa0 secondary IP from the server ?
What's the server default gateway ?
Can you ping out to the internet when sourcing from Fa0 secondary IP ?
ian
no
Ian,
Can you elaborate a bit more ?
ian
I perform the ping with the following results.
Router#ping 66.178.167.3 source 66.178.174.78
Sending 5, 100-byte ICMP Echos to 66.178.167.3, timeout is 2 seconds:
Packet sent with a source address of 66.178.174.78
Success rate is 0 percent (0/5)
Router#
ian
This should have been a reply to a different message
Gold
Depends on what address your sample ping implies
You should be able to ping 66.178.174.73 with a source of a.b.c.d If this does not work then your ISP has the routing messed up.
Now if you are tring to ping between a.b.c.d and w.x.y.z you are going to have a number of issues. Partially it is that it is hard to test using the router interfaces because of how nat works. You also have issues running nat when the inside and outside interface are the same interface. This configuration is called nat on a stick but I would not recommend it as other than a last option.
It should be possible to talk between 192.168.10.x and a.b.c.d network if you have your gateways and subnets setup correctly.
385
