Webcast-Catalyst9k
Purpose of Network Management Port at C4503
Hi Ciscoer,
Could any1 here explain for me what the purpose of Network Management port at the Supervisor Engine IV? Attached with what the Network Management port? And how to InterVLAN routing with 4503 (any cisco link and sample?)
Thank YOu
HATO
Re: Purpose of Network Management Port at C4503
The management port is used for disaster recovery. If you delete all IOS images and if you do not have a flash card, you can use management interface to recover the supervisor. This port is not active when the supervisor is up and running and can only be accessed in rommon
http://www.cisco.com/warp/customer/473/149.html#image
Configure layer 3 VLAN interfaces to route between VLANs
http://www.cisco.com/univercd/cc/td/doc/product/lan/cat4000/12_1_13/config/l3_int.htm#1029700
HI thank you before,
Hm....is it only for disaster recovery? No other purpose? Also have try to configure the L3 Vlan Routing. I have create a vlan called 2. I cannot ping the interface from the C4503(the shor interface vlan 2 show me that the interface and protocol down/down) but I can ping from the workstation.
Any suggestion?
THank you for your quick response
HATO
For the layer three VLAN2 interface to be up/up, you need to have some device in VLAN 2.
http://www.cisco.com/warp/public/473/188.html
181
