puzzling problem
Hey all,
I have a peculiar issue with port security. Basically what's happening is this. I have User A and User B who can not communicate with each other (icmp, ip, everything) but have no problems with anyone else. We're all on the same vlan and on the same switch. Port security is enabled with the same settings on all machines. If I were to disable port-security on one of the users, then both users can ping/connect each other. What's wierd is I don't have to disable on both. No one else seems ot have this issue. However this has happened once more after and the only similarity between them all is that they were all from Dell Optiplex 620s.
Silver
Re: puzzling problem
Please provide the config.
DId you try to move the PC to other ports and test ? If move to other port but still the same, it looks like the porblem of the PC not the switch. Any firewall installed at the PC block those packet ?
Hope this helps.
I haven't tried moving them to other ports and no firewalls are installed on the PCs. However if I toggle port-security on one of the PCs you can definitely see the difference (turned on it can not be pinged by this one machine nor vice versa).
Here's a sample config of what I use:
version 12.2
no service pad
service timestamps debug uptime
service timestamps log datetime
service password-encryption
service sequence-numbers
hostname switchA
enable secret 5 blah
enable password 7 blah
username blah password blah
aaa new-model
aaa authentication login default group tacacs+ local
aaa authorization config-commands
aaa authorization exec default group tacacs+ local
aaa authorization commands 15 default group tacacs+ none
aaa accounting auth-proxy default start-stop group tacacs+
aaa session-id common
clock timezone UTC -5
clock summer-time UTC recurring
ip subnet-zero
ip dhcp snooping vlan 1
ip dhcp snooping
cluster commander-address mem
no file verify auto
spanning-tree mode pvst
spanning-tree portfast bpduguard default
vlan internal allocation policy ascending
interface FastEthernet0/1
switchport mode access
switchport port-security maximum 2
switchport port-security aging time 1
switchport port-security violation protect
switchport port-security aging type inactiv
ip dhcp snooping limit rate 100
interface GigabitEthernet0/1
switchport mode trunk
ip dhcp snooping trust
interface GigabitEthernet0/2
switchport mode dynamic desirable
interface GigabitEthernet0/3
interface GigabitEthernet0/4
interface Vlan1
ip address 10.10.10.1 255.255.252.0
no ip route-cache
ip classless
ip http server
ip http access-class 1
ip http secure-server
snmp-server community
tacacs-server host 10.10.10.6
tacacs-server directed-request
tacacs-server key 7 blah
radius-server host 10.10.10.6 auth-port 1645 acct-port 1646 key 7 blah
radius-server source-ports 1645-1646
radius-server vsa send accounting
radius-server vsa send authentication
control-plane
alias exec macsh sh mac-address | include
alias exec arpsh sh arp | include
line con 0
line vty 0 4
access-class 1 in
password 7 blah
line vty 5 15
password 7 blah
ntp clock-period 36029099
ntp server 10.10.10.9
end
Silver
For below commands :
Did you try to remove it one-by-one and test what command casue the problem ? And, can confirm the aging time is 1 mins ? I suggest to try to remove "violation" first and test then remove aging and test again.
And, is this port connected w/ more than 2 PC at the same time, you configure maximum 2 and it limited 2 MAC address only.
125
