Community Member
PVLAN and VLAN question
I need to work out how to add a single port to a VLAN on a switch that is using PVLANS.
For example port 3/7 is in VLAN 600
I want to add port 4/6 to VLAN 600 but am being told 'unable to add port to vlan use pvlan command'
The only PVLAN is isolated, and I do not want port 4/6 isolated, it is a backup server and must be able to connect to other devices.
Any ideas?
1 REPLY
Community Member
Re: PVLAN and VLAN question
I guess it will look like this (if you run CatOS):
set pvlan mapping PRI_VLAN SEC_VLAN 4/6
Where PRI_VLAN is your primary VLAN id and SEC_VLAN is your isolated VLAN id.
//Mikhail Galiulin
108
