Community Member
PXF problem
I have a Cisco 7206VXR with NSE-1 which is doing large number of NAT translation( about 20000), At the peak time, the high CPU of the RP can be seen. When I check the PXF switching statistics, I found About 20% packets were punted due to "NAT OUTSIDE", "NAT INSIDE" and "NAT TCP FLAGS".
I want to ask which type of traffic caused to these punts and how can I reduce these punted packets and let them pass the PXF processors?
EDU-7206-A#sh pxf account summ
Pkts Dropped RP Processed Ignored
Total 0 10625677 0
PXF complex busy: 16% PXF read pipeline full: 0%
PXF Statistic:
Packets RP -> PXF:
switch ip: 0
switch raw: 51066262
qos fastsend: 0
qos enqueue: 0
Total: 51066262
Packets PXF -> RP:
qos pkts: 0
fast pkts: 40440585
drops: total 0
punts: total 10625677
" not IP : 8565
" NAT TCP flags : 1001868
" NAT version : 3662
" NAT inside : 2243047
" NAT outside : 7323872
" CEF no adjacency : 44221
" IP TTL : 442
Total: 51066262
Packets ignored: 0 | ring space:
shadow ring full: 0 | shadow ring: 16382
in ring full: 0 | inring: 991
PXF inactive: 0
tx credits: 0 | delayed credits: 0
holdq enqueues: 119359 | requeue drops: 0
interrupts: 40122912 | pending read bytes: 0
Interface Pkts In Chars In Pkts Out Chars Out Punted Dropped
Fa0/0 0 0 0 0 0 0
Fa0/1 0 0 0 0 0 0
Gi1/0 0 0 0 0 0 0
Fa2/0 22862379 1372404270 18136316 3555446479 2732483 0
1 REPLY
Bronze
Re: PXF problem
The PXF will punt the NAT traffic to the CPU in the following cases:
1. more than 65K entries
2. traffic contains embedded addresses (such as ftp) all the packet will be punted on that flow
3. FIN/RST/SYN packets
4. new tranlation entry
By reducing the NAT timeout, it is possible to reduce the number of packets punted to the CPU.
164
