Community Member
QoS : CBWFQ on GRE Tunnels at ATM/FR circuits with IPSEC using DSCP mark
i have a problem about the Class-Based WFQ shaping.
i am running ATM at the HQ site and the Frame-Relay Circuit at the remote sites. i am also applying IPSEC with GRE tunneling.
Inbound packets are marked with DSCP flags and outbound shaping is determined by checking the IP DSCP bit field.
i get the following results when trying to perform FTP from the remote site to the HQ simultaneously: - 32KBps (Assign=80%, actual=29%) - 77KBps (Assign=10%, actual=71%)
Can someone has experience about CB WFQ shaping on ATM subinterface with IPSEC GRE tunneling ?
Configuration Highlight
boot system flash disk0:c7200-ik9s-mz.122-8.T5.bin
access-list 2300 permit ip host any
access-list 2301 permit ip host any
access-list 111 permit gre host host
crypto map tunnel11 10 ipsec-isakmp
set peer <ip address>
set transform-set vpn_set
match address 111
qos pre-classify
policy-map inbound
class smartics_tra_1
set ip dscp 1
class other_tra_1
set ip dscp 4
policy-map outbound
class dscp1
bandwidth percent 80
class dscp4
bandwidth percent 10
class-map match-all dscp4
match ip dscp 4
class-map match-all other_tra_1
match access-group 2301
class-map match-all dscp1
match ip dscp 1
class-map match-all smartics_tra_1
match access-group 2300
interface Tunnel11
ip address <ip address>
tunnel source <ip address>
tunnel destination <ip address>
tunnel key < deleted >
crypto map tunnel11
qos pre-classify
interface ATM2/0.11 point-to-point
mtu 1500
bandwidth 1500
pvc 22/32
vbr-nrt 1500 1500
max-reserved-bandwidth 90
tx-ring-limit 3
encapsulation aal5snap
ip addr inarp
service-policy output outbound
crypto map tunnel11
Re: QoS : CBWFQ on GRE Tunnels at ATM/FR circuits with IPSEC usi
Though I have tried QoS with IPSec, I have not configured it over ATM. Just wondering if the ATM traffic parameters have got something do with the rates that you are observing. You can check whethere any of these documents give you some clue :
